twin TD04 project
i was thinking of doing a twin TD04 project on the svx, my only issue is the maf sensor.
currently i'm running ECUtune 2v4f(iir) setup. looking into this people use a speed density setup to remove the maf all together, has anyone done this on an svx?
Re: twin TD04 project
I haven't heard of anyone running speed density on an SVX. Maybe on one of those insane drag builds on a swapped Impreza. The Hydra uses MAP (manifold absolute pressure) sensor, which also does away with the MAF and opens up the HP restriction.
Another option is to have a single air filter, MAF, and then a y-pipe to the turbo inlets if you have the space available (I don't know what layout you're thinking of). Good luck!
You're probably thinking of alpha-n.
Well how about that... My understanding of speed density was that it's based on intake air temperature and an engine load/airflow table.
Please forgive my ignorance.
Yea that sounds like alpha-n. Basically in alpha-n, the airflow is determined from just the TPS and the engine speed/displacement. In fact, there was an SVX running in alpha-n, dynomatt's rally car, with the megasquirt 2.
td04's are cheap as dirt. still want to see where this thread goes.
