Old 01-24-2008, 02:24 PM
JLHollowX13's Avatar
JLHollowX13 JLHollowX13 is offline
Send a message via AIM to JLHollowX13
CV Axle replacement tips
im about to replace the cv axle on the drivers side. does anyone have any hints or tips to help me out? things i should look out for or be prepared for ahead of time that the how-to may not have said? thanks!
Old 01-24-2008, 03:35 PM
Cal me and I can walk you through it.
301-707-3437
Old 01-24-2008, 08:29 PM
ShiuludeSVX's Avatar
ShiuludeSVX ShiuludeSVX is offline
Send a message via ICQ to ShiuludeSVX Send a message via AIM to ShiuludeSVX Send a message via Yahoo to ShiuludeSVX
I just did mine last week, and the "How To" document covered it very nicely.
Test the Roll Pin direction before installing.
Tom was a big help too, so get him, if you can.
Remember not to crank the Axel Nuts down with an air gun tho.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 01-24-2008, 08:38 PM
While this subject is going, is torque on the front axle nuts also 151 ft-lbs? I'm putting in ball joints this weekend.
Edit: Decided to move my lazy mouse hand and check the how-to's myself. Torque is 123-152 on the front.
Old 01-24-2008, 08:45 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
I torque them to 150.
If you're doing ball joints, you don't need to take off the axle nut? If you do, take them off, either use a new nut, or make sure that there is enough "stake able" collar to re-stake them properly.
Old 01-24-2008, 09:00 PM
I have a new one already.
For the ball joints, do you just remove the pinch bolt (in the knuckle), remove the three bolts in the arm, and then pound it straight out? Makes sense. Remove pinch bolt, hammer until ball joint comes out of knuckle, remove the bolts, hammer until bracket comes off. Torch as needed.
Old 01-24-2008, 09:03 PM
Hocrest's Avatar
Yeah, you have the order right.
Undo the pinch bolt and pound down on the control arm to get the ball joint out of the spindle.
Then undo the 3 bolts and you're done.
