#256
Re: Total manual transmission SVXs on the Network
96-97's are OBDII which will have a Check Engine light with a manual.
1994 SVX L - FWD Barcelona Red 190K miles ~ SOLD 1994 SVX LS - 5spd AWD Emerald Green 202k miles PWR Radiator, HID 5000k, New paint job with issues, 17" STI BBS wheels, converted to 5spd AWD from FWD. Purchased from SVXyGirl 2/20/09 -- Undergoing complete rebuild 1993 Justy 4wd 5door- Teal of sorts , beater. 2008 OBXT Newport Pearl 65k miles |
#257
Just curious. Can you put the gear(s) for 6th gear on a 6MT in a 5MT for 5th gear?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
#258
And what would the gain BE
#259
I am almost 100% sure, no. Would you be trying for a taller or shorter 5th gear?
#260
In the 6MT 5th & 6th come as a set and are, I think, on the same shaft. Internally (and externally for that matter) the two gearboxes are completely different. Different "families" even, for lack of a better word.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* |
#261
Taller...assuming I get the difference correctly.
#262
From what I recall, tallest top gear in any manual Subaru makes would be the Legacy Spec.B; 3.90 final drive with .707 6th. The JDM Forester STi also has the .707 6th, but I think it might have been 4.44 final drive.
Next highest, probably the more recent (08-09?) WRX with 3.70 diffs, and I think .738 5th gear. Other WRXes also get this 5th gear, but with 3.90s. Ultimately, the 3.70 & .738 combo is the taller of the two, but not by any noticeable amount. The 3.90/.738 WRX is easier to find by far. USDM STi boxes are a good option if you want a 6MT - 3.90s with .756 6th (or something) - pretty close to the WRX. Food for thought, if you're thinking about swapping. I ended up with the same ratios as Icingdeath. My highway mileage went from about 30mpg to 25 or so, and I drive slower now (55-65mph instead of 70-75). If I could do it all over again, I would have gone for the Spec.B gearbox, despite not having a limited slip in the front diff. An LSD in the front can actually hurt street performance (cornering) unless you're driving through snow and slush or mud, which, most of us just don't do.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto. 1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong! 2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver. 1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver! 2007 Honda CR-V, some awful shade of light green *yawn* 1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED. 1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust* Last edited by Nemesis Destiny; 09-22-2011 at 09:59 PM. |
#263
Yes, it would be difficult to find an STi 6mt with as tall of a 6th gear as a WRX's 5th. The 6th gear isn't there for gas mileage. The goal is closer gearing throughout, so that you can always have the exact right gear to keep you in the rev range, to better utilize the turbo. The 6mt is for getting around the track (or w/e) faster and handling tons of power with ease.
I don't know how easy it would be to find a legacy spec B gearbox, but that sounds like it would be just the ticket for an SVX. And I'm sure you can have a LSD swapped in if you wanted. Quote:
#264
#265
The 2008-2009 Spec B have the same 6th gear as the '08 US STI. I'm not sure about the '09 STI. These are by far the tallest gears you're going to get.
I have a hell of a time in some instances trying to mash into some people's heads that just because it's called 6th gear doesn't necessarily mean it's taller than 5th! The 5th gear in my '00 RS equipped Pearly is comparable to 6th in the Silver. The only real difference is the number of shifts it takes to get there. With the extra guts from the supercharger, I don't need to hit all the gears and usually skip some. It's a lot of rowing otherwise! Er, back to your regularly scheduled list thread...
Disclaimer: The above post is on the internet. |
#266
Finally get to join the party!!
1. huck369- 5mt now CigarJohnny's 2. LetItSnow (previously Tomssvx's) - 6mt* 3. gsodonis- 5mt 4. ensteele- 5mt 5. alex_umn- 6mt 6. Earthworm- 5mt donor=2002 WRX 3.90 (2nd 5spd in Canada) 7. Subafreak- 6mt 8. GreenMarineSVX- 5mt 9. mbtoloczko- 5mt 10. Phast SVX- 5mt turbo 11. UT_SVX- 5mt 12. svxsubaru1- 5mt 13. mohrds- 5mt 14. wawazat- 5mt 15. svxtasy- 5mt turbo 16. Earthworm's dad- 5mt (previously belonging to Green1995SVX) 17. robricc 2002 WRX- 5mt 18. TXCESSVX- 5mt 19. SilVerXtc- 5mt 20. AvPPoW- 5mt 21. Huck369's parts car- 5mt 22. Shotgunslade- 5mt* 23. Rmjjensen- 5mt 24. Wiznutwrx- 5mt (previously TomsSVX's)* 25. Motorsport-Svx Silver 5mt (sold a few yrs ago) 26. ensteele- 5mt (previously TimH ) 27. Want-a-fast-svx 28. Strange179- 5mt 29. Double0Bondo- 5spd 30. bcpianoman - 5mt, donor 2003 WRX 3.90 (Vancouver Island, British Columbia) 31. Mikecg- 6mt Stage III* 32. Speedklix - 4.11 5mt 33. kulaid - 5mt 34. Ricochet 4.11 5mt 04 RS* 35. SVXyGirl's brother (previously LetItSnow's) 4.11 5mt 00 RS* 36. Gest24 6mt 05wrx sti* 37. Sov13t 6mt 04wrx sti (svxfiles did the conversion) 38. bcpianoman's son - 5mt, donor 2004 WRX 3.90 (Vancouver Island, British Columbia) 39. Nemesis Destiny - 6MT; JDM v.8 (3rd 6MT in Canada to the best of my knowledge as of November '06) 40. Mr.Pwrlite - 5mt (since 4/03) Wow!, more converted SVX's than I thought. 41. svxcuseme- 5mt, 2002 WRX. 42. SVXBart- '04 Wrx 5mt* 43. AFBeefcake- 5mt 2002 WRX 44. Huck369 - 5mt 95 Impreza 3.90 (Just finished a 5-speed swap in my Pearl Yellow one) 45. Benehoc Racer - 5mt* 46. Steven_esworthy - 5mt WRX 47. Pat from Pgh. (Not yet on The Network) 5mt, 1993 SVX 48. Pat from Pgh. (Not yet on The Network) 5mt, 1992 SVX 49. Porschekiller - 4.44 5mt* 50. SVXRide - 3.90 5mt w / R180* 51. Reading Raffle Car - 4.11 wrx 5mt* (Now SVXBart's) 52. Marlepat - 3.9 Imp 53. JaySVX - 3.90 WRX 5MT* 54. Nforcer - 4.11 legacy GT 5mt 55. Lockleaf - 5mt, 99 Impreza 56. Johnybeas- 5mt, 02 WRX 57. BenSVX - 5mt, Impreza 58. jeffast - Just killed a legacy 4.11, soon with impreza 3.9 59. Guyver280Z - 5mt Forester 60. SVXapeal- 5mt '04 WRX 61. subster – 5mt 02 WRX 62. Petesvxny- 5mt 4.11 legacy gt 63. Tim - 3.90 5mt w / 3.545 rear diff* 64. GreggBzz - 4.11 5mt* 65. NikFu S. - 02 WRX 5MT 66. LiquidForce 5mt 67. Djsvxxl- 07 wrx 5mt* 68. f1svx - 3.90 5mt installed 2002 69. SVX10 - STi gearset 5MT installed 2005ish 70. sicksubie - 07 Sti 6mt 71. Mike621- 98 4.11 5mt* 72. Shelfy- 05 LGT 5mt* 73. Jokethis89- 98 Legacy 4.11 5mt 74. RoughSilver92- 06 2.5i 3.90 5MT 75. Stiguy- 03 wrx 5MT 76. Jim Lough- 07 WRX 5mt* 77. -JJ- - WRX 5MT 78. The_Paynter- 2002 V7 STI 6mt/DCCD 3.90 (This car was parted out and non-DCCD) 79. 95greensvx - 92 ls-l 5mt 80. Wikedjuggalo - 5mt 3.90 81. Alex-svx - 5mt 3.900 82. Gamesy - 5mt 04 WRX 83. Ridered777 - 5mt 96 legacy 3.9? 84. Icingdeath88 - 6mt 2002 JDM STi V7 (non-DCCD) 3.900 85. Crazy_Pilot - 2007 USDM 6MT
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 09-10-2012 at 12:34 PM. |
#267
Updates in bold. Last edited by 1986nate; 09-10-2012 at 01:47 PM. |
#268
Add me to the list soon
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#269
I should be on there. '92 Lsl Claret- '93 Legacy Turbo 5sp
Elazar '08 ML550 daily driver '13 F150 work truck '87 MR2 racecar '92 Lsl Claret 5sp "Be kind to your motor car." - Jackie Stewart |
#270
look at #85
