Old 07-31-2010, 03:49 PM
Re: easter eggs?
#11, When your power seat belt stops working, you can wire it to the rear window switch to manually operate it...
Old 07-31-2010, 03:53 PM
LetItSnow's Avatar
Still Cant' Say the Z-Word
Re: easter eggs?
#12: When the gas tank needle goes all the way past E and around to F again, you might actually be low on gas.
Old 07-31-2010, 04:13 PM
Re: easter eggs?
#7, There are tiny detonators hidden in the rear wheel bearings programmed to explode when you don't have an available $300.00!
fixed your post
Old 07-31-2010, 04:15 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: easter eggs?
#13: Check your model year. If your SVX is a 92-97, you need new headgaskets.
Old 07-31-2010, 05:25 PM
92_LSL's Avatar
92_LSL 92_LSL is offline
Re: easter eggs?
#14 if you put a 10 amp fuse in the spot marked FWD the car magically switches to front wheel drive !
I has teh FWD LS-L
Old 07-31-2010, 07:58 PM
Re: easter eggs?
#15, You either just bought a new radiator, or are about to buy a new radiator.
Old 07-31-2010, 08:05 PM
Re: easter eggs?
So much truth spoken in this here thread! Keep 'em coming.
Old 07-31-2010, 08:06 PM
Gamesy's Avatar
Gamesy Gamesy is offline
Re: easter eggs?
forget i ever asked
Old 07-31-2010, 10:40 PM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: easter eggs?
Originally Posted by Gamesy View Post
forget i ever asked
Why? This is one of the best threads evr!
Old 07-31-2010, 11:26 PM
Invisible avatar
Question Re: easter eggs?
When you push the power window button(s) down, only half of the glass retracts into the doors. Is this an easy fix?
Ron.
'96 Grand Caravan - 240K
'01 Miata SE - 79K
Old 08-01-2010, 07:14 AM
Re: easter eggs?
Ron.
The easiest way to open them the rest of the way is with a hammer...
...closing the other half? not so easy
Old 08-01-2010, 03:56 PM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
Re: easter eggs?
I think the power mode mod for USDM cars probably counts as an Easter egg.
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 08-01-2010, 04:26 PM
Cam Cam is offline
Re: easter eggs?
That was the case with me (7 failures, 5 on one side and 2 on the other)
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 08-01-2010, 05:54 PM
Re: easter eggs?
Yea that and the summer/winter wiper modes are the only ones I could think of.
Old 08-02-2010, 02:10 AM
SoCal LS-L's Avatar
Avalanche Alcyoneer
Re: easter eggs?
#16: If you hold the keyfob up to your chin while pressing button, it opens an inter-dimensional gateway through subspace, allowing the range to be increased almost infinitely! I didnt believe this one until I tried it...
