Old 05-17-2011, 08:36 PM
nastysvx92's Avatar
nastysvx92 nastysvx92 is offline
Check engine light STILL on
Hi SVX network, i bought my 92 svx in late 2008, since that moment my "check engine light" was on all the time, i have had replaced the oxygen sensors already and i did not have luck. What else could be the problem here?
*i have replaced radiator, alternador, timing belt, water pump, and changed all my filters regularly.
thanks
Old 05-17-2011, 09:19 PM
Re: Check engine light STILL on
thanks
Come to The Reading Meet, and I will run my SSM on your car and tell you what is wrong.
Old 05-18-2011, 12:56 AM
SVeXy96's Avatar
SVeXy96 SVeXy96 is offline
Sold my soul to Subaru
My check engine light has been on since 2006!!! I just said screw it and bought my own diagnostic. I check it every now and then and in the 5 years that thing has been flashing I only threw a code once and it was for my TPS. I stuck one of those adhesive air fresheners in front of it so its not so noticeable
Meow
Old 05-18-2011, 02:43 AM
b3lha's Avatar
b3lha b3lha is offline
Phil & Belha
What trouble code is it giving you?
http://www.subaru-svx.net/forum/showthread.php?t=54033
Subaru ECU and TCU Website
1992 Alcyone SVX Version L
1994 Alcyone SVX S40-II
1988 Subaru Justy J12 SL-II
Old 05-18-2011, 07:45 AM
nastysvx92's Avatar
I'll be glad to, but i can't go this year
Old 05-18-2011, 07:46 AM
nastysvx92's Avatar
LOL, i'll probably do the same if i can't solve this problem.
Old 05-18-2011, 07:47 AM
nastysvx92's Avatar
Thanks, this will be very helpful.
Old 05-18-2011, 08:44 AM
kinz kinz is offline
Even if the code is o2 sensor is the code you get doesn't mean that's the issue, simply that the system detects an abnormal reading from it.
For example I had a cel for an o2 sensor that came up after driving 30 min or so. It wasn't constant, but consistent. I cleaned the maf and changed air filter that was overdue. Haven't seen a cel recently.
13 Mazda3 iGT Grey Mica | 13 MX5 Club Red | 10 Vstar 650 Black
92 LSL Pearl 205k+ mi. 4.44 Trans (no 1st or reverse) | VR3 deck, Shark class-D amp, 6.5" bass tube, JVC front, Lanzar rear | SPD trunk struts. Gotta get ones for hood, the random auto store ones don't cut it. Vice grips work tho | DDM HID's 55W shining nice and white.
Old 05-18-2011, 09:08 AM
3.3H6's Avatar
3.3H6 3.3H6 is offline
Limecat is not amused.
http://www.youtube.com/watch?v=apWUhBiqRyw
1992 Subaru SVX: sold after months of problems.
1995 Volvo 850 T5R sedan
2011 Subaru Outback 3.6R limited: excellent all-rounder
