Old 03-24-2011, 10:40 PM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
driver's belt is "sticky."
so when i want to get out of my car, my seat belt goes up about an inch, then get's stuck. rarely it will free itself and go all the way. i usually just smack it with my left hand, and it unsticks and goes all the way up without a problem. goes back down fine when i close the door. passenger door doesn't stick at all. i was going to spray a little WD40 on it, but i decided that might be a bad idea because it probably needs friction to work. anyone else have this problem? it bugs the heck out of me that i have to hit the seatbelt/tug on it every time i want to get out of the car.
also, if i don't hit it up after 30 seconds or so, it will get stuck in that position until i close the door and open it again.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 03-24-2011, 11:25 PM
Re: driver's belt is "sticky."
Ya, mine does that too. I just add "shake the seatbelt thing" into my get in/out of the car ritual.
Actually, having driven my 240 for the last 5 months while the SVX was sleeping I'm going to have to get back into all sorts of habits.
Old 03-25-2011, 07:04 AM
You could change out to manual seatbelts... I have a set of stuff to convert them.
Old 03-25-2011, 07:22 AM
B 4 You's Avatar
#lolsvx
it seems to not be as bad when it's really warm out too. i actually love the auto seatbelts though. i love when people get into my car and strangle themselves with it. it's hilarious. anyway, if anyone has a cure for this please let me know :]
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 03-25-2011, 07:26 AM
I also have the auto seatbelt motors/tracks if you decide that's what you need.
Old 03-25-2011, 07:30 AM
B 4 You's Avatar
#lolsvx
if that's the only way then i'll go that route. can i spray WD40 in it? i'm assuming no because i'm pretty sure it's belt driven and belts need friction to work..
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 03-25-2011, 08:49 AM
Green1995SVX's Avatar
It's just one of those things that comes with aging svxs. Eventually you'll become so used to hitting it with your hand that you wont even notice.
Think of this scenario that happened to me.
You pull up to a ticket machine at a parking garage. Reach out the window. "oh, because of this stupid half window, I can't reach all the way." While your head is out the window, you open the door for extra room. When you do, the seatbelt wraps around your neck and pins your head in the corner of the window. Everyone in the car with you laughs.
Mike
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 03-25-2011, 09:27 AM
Cable driven. I don't think some WD40 would hurt, just don't go nuts. And try not to get any on any of the interior bits. If it weren't extremely likely to break the clips that hold it on (especially if it's cold and brittle), I'd suggest taking off the A/B pillar cover to make sure of that and inspect it good.
Old 03-25-2011, 09:38 AM
B 4 You's Avatar
#lolsvx
mike, i know exactly how you feel. drive thru's get the best of me. as far as ticket booths, i don't open the door, but i do stick more than half of my body out to get the ticket. one day i'm going to fall out. and i love when friends put the seatbelt behind them as they get out, not knowing they're about to be strangled.
how do i take apart the fixture? i don't think it's weak or brittle. it looks like it's in pretty decent condition. i will try a dab of WD40 tonight and see if it does anything. it almost feels like it's confused whether it should open or not.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 03-25-2011, 09:59 PM
A while back a member figured out what to do to fix it. It was a simple fix and I don't remember what it was and now mine is doing the same thing. If anyone remembers who it was or what the fix is, I will try to get it into the How-To Docs.
Old 03-28-2011, 09:31 AM
B 4 You's Avatar
#lolsvx
hopefully they can help me.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 03-28-2011, 01:36 PM
K_Dub's Avatar
K_Dub K_Dub is offline
Headin' for the hills
Am I having Déjà vu?
http://www.subaru-svx.net/forum/show...9&postcount=16
It looks like you've got the same symptoms that I had prior to this fix.
'92 LS-L "Bandit" #362 formerly dark teal, repainted by prev owner
Mods: ECUTune 2v7f, Earthworm bushings, Pioneer DVD/Bluetooth phone, Infinity Reference all around, tint, 17" wheels, custom seat belt computer, velcro visor
Buying parts is like car payments. Someday she'll be all mine.
Old 03-28-2011, 01:44 PM
B 4 You's Avatar
#lolsvx
i'd love to say you were, but i think mine is slightly different...
correct me if i'm wrong, but my seatbelt works 100% of the time, it just gets stuck once it's in the all the way down position. it moves about an inch up when i open my door, and once i wiggle it "free" it opens all the way. e.g., if i close my door, and open it right before it latches, it'll go all the way back up. so i don't now. i read that other post to see if it was the same thing. if that's the solution for mine though, i'll take it.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
