Old 05-12-2010, 12:44 PM
zooandbio4me zooandbio4me is offline
Definitely a stupid question.. Axle cap?
Need to re-boot the axle on pass side. Anybody have any good tricks for removing the cap? Tried to pry it off with a lil screwdriver, a chisel etc etc.. No luck, thinking about threading a bolt in to pull it off? What am I missing here? lol
Old 05-12-2010, 06:28 PM
michael's Avatar
michael michael is offline
What Potholes ???
Re: Definitely a stupid question.. Axle cap?
??? a little heat, channel locks ???
Wanted: Steering Wheel
Old 05-13-2010, 05:02 AM
sowise sowise is offline
should just be a matter of tapping it out with a screw driver and hammer or chisel and hammer works well, once you get the cap seperated a little a screwdriver can pull it the rest of the way off. Soak it with lube PB blaster or WD-40 may help. Also don't tap straight down you kind of have to tap from an inside to outside direction. Cap would be pretty replace-able though if you do end up damaging it.
Old 05-13-2010, 05:18 AM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Shotgun???
Old 05-13-2010, 07:26 AM
Originally Posted by Hocrest View Post
Shotgun???
C4!
I usually start the removal with a gasket scraper, and as soon as I geta gap started, use a screwdriver to pry it off.
Old 05-13-2010, 08:23 AM
NeedForSpeed NeedForSpeed is offline
+1, use a flat chisel, work your way around once if pops up
Good luck, and welcome
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-24-2010, 06:52 PM
subarufamily subarufamily is offline
GRENADE, IT'LL COME OFF THEN ( or be in such small pieces it wont matter)
William
Old 05-24-2010, 07:17 PM
I've just used a sharp (alright, maybe a little less sharp now) chisel. I've seen a few at work that were stuck real well, but they all come out in the end, although they're generally so mutilated that they will never be used again.
