Leaks And Prices Causin Havoc, Need Advice.
I got 2 leaks one in the lp p/s return hose and one from the valve cover gaskets, plus i need a new p/s pump the noise is killin me!. Hose wasen't a problem but, Everyone is askin 355$! for the pump its killin me, anyone know were i can get it cheaper, maybe an acdelco or a1 pump, or a private seller willing?.
Plus the other problem im havin is 1 dealer is tellin me thier are 3 valve cover gaskets on each side, plus i need new bolts and he's chargin me 13$ each 4 the gaskets plus 3$ each for the bolts theirs like 4 sets of them or somethin he says gettin 2 is riskin containin the leak....total thier with shippin was 125, thier from a subaru dealership, and claim theyve worked on it. Meanwhile the other dealer is tellin me he knows that 2 valve cover gaskets will be enough to stop the leak, and 2 sets of bolts will be enough, makin me save, total their with shippin was 80 what should i do, and who should i trust here? anyone worked on these issues or know exactly whats best here? need this done asap. Would appreciate some help thanks. |
Re: Leaks And Prices Causin Havoc, Need Advice.
There are 3 rocker cover gaskets on each side and 20 washers that seal the mounting bolts.
You will need to replace all of the gaskets to stop the leak, but you can reuse the original bolts-- no need for new ones. See page 3 of THIS DOCUMENT for the replacement diagram with part numbers. The only thing not shown are the rubber-lined washers for the bolts (#3 on the diagram). The part number for those is 13271AA051 and they are about $2.50 each ($50.00 for all of them) I just did this job less than 2 weeks ago. As for the P/S pump, what are the symptoms? Usually it is the O-ring that goes bad between the fluid reservoir and the pump itself. It allows air to enter the system and causes erratic steering and lots of noise! It is a $1.00 fix and takes about 20 minutes. Try this first Look in the How-to Documents HERE and HERE to familiarize yourself with the procedure (which is fairly easy) . ,
. Subaru Ambassador 1996 Polo Green LSi #216..138,100 miles...SOLD JFICX8659TH100216.....Date of Manufacture: November 16, 1995..... Fuji Heavy Industries..Ōta North Plant....Ōta City,. Gunma Prefecture, Japan In-Service Date: January 2, 1997 "The Pristine Green Polo Machine” First Polo Green on the Network First Clear front turn signals, JDM Alcyone hood emblem, rear panel, and BOXER engine cover on the Network (US) (2000) First 5000K HID factory fog lights (2007) First SVX JDM BBS wheels on a USDM SVX (2013) HID lighting (5000K) for headlight and H3 fog lights, PIAA SuperExtreme 120W high beams, rebuilt EG33 longblock, Cometic head gaskets, Phase II flexplate, AMR aluminum radiator with custom silicone hoses, 160A high-output alternator in aluminum-ceramic coated case, new design alternator wiring upgrade v.4, rare factory headlight protectors, refinished JDM BBS mesh aluminum wheels and custom, polished billet aluminum new hex center caps, LED grille mod, R1 Concepts high-carbon cryo slotted rotors, Akebono ceramic pads, Goodridge S/S braided brake lines, Smallcar Stage 1 shift kit, ThermalTech aluminum/ceramic-coated valve covers, Energy Suspension urethane front & rear swaybar bushings, Bontrager22 rear swaybar with QS Components Chromoly Teflon/Kevlar endlinks, "$15.00/5 minute" suspension mod. Hella Supertone horns, Custom stainless steel exhaust system with 2" headpipes, Magnaflow cats, AeroTurbine AR25 resonator /AWD "Bullet" muffler. R.I.P. 2010 Subaru Outback Limited 2.5 CVT...338,000 miles. Totaled by a 1,300 lb. COW March 4, 2016 2014 Hyundai Avante Limited ...178,000 miles. Actually quieter and smoother than the Outback 2007 Mazda Miata MX-5 PRHT...102,000 miles. Plenty of parts, service and windshields. 4th Registered Network member —2/21/2001 My NEW locker..I...My Email..I..Wikipedia/SVX . . Last edited by svxcess; 10-20-2008 at 10:55 AM. |
Thanks, i dont have enough for the pump right now anyway, and im already paying my mechanic to change the valve cover gaskets and the p/s hose. So ill print these out and hand it to him,I l tell him to do that procedure when he changes the hose, hopefully i might not need a new one, appreciate the help.
I cant find a manuel on the how to do documents on The valve cover gaskets, Any help? The mechanic is good but im so cautious with the car,.... gettin that how to do on the gaskets, would be a big plus!. And 1 last thing is.....how do u lock the doors on the factory subaru, don thave any remotes or prestige, when i bought he told me somethin about liftin the handle, and lockin the door any help? |
They have remote locking. Sometimes you can pick up the key fob on ebay. Somewhere here there are instructions on programming the fob.
Gene
To lock the door, you lock it from the lock switch on the drivers door, and you have to hold up on the outside handle while you close the door.
..or you can lock it with the key after you shut it....
Yeah Huck thanks, it dosent lock from the outside, it only opens,...... so, im gonna try it today, lock the door from the inside then hold up the outside handle and close it.
Will let u know if it worked, that's what the seller told me but i kept doin it wrong. thought it was the inside handle, i had to hold for 3 seconds before lockin, it was weird anyway ima let u know wasup, thanks again. |
If you want a new pump, go to www.rockauto.com, they have everything you need for less than others for name brand stuff. The AC Delco reman PS pump is 171.79, with the send in for rebuild priced at 117.79. I have ordered their brakes and other stuff and the shipping is fast and I had no problems. Good luck
The spot you describe is where the hp hose is. You can take it off and get it rebuilt at a shop that deals in hydraulics(backhoes,loaders etc.) You should be able to see it leaking by shining a light down there and getting someone to turn the steering wheel back and forth.
There are lots of spots that could be leaking, but Blacky is right, the high pressure hose is most likely. Other possibilities are a cracked hard line on the rack, REALLY blown seals in the rack...
Appreciate the help, Socal i talked with rock auto, and the 117 is out of stock, and they have the acdelco one wich takes 12 days to ship cause they have to pre-order, sources say acdelco may not be a good fit, even though its replica. And im going to take hucks advice and guess its the o-ring, the noise cools off alot ones i put some tranny fluid but it leaks it all out in 1 day!. Its drivin me nuts, im figurin if i fix the lp and hp hoses, get a new oring and flush the pump the nightmares will end. So far the valve cover gaskets and lp hose with the oring and shipping came out to 125. Im guessin the hp hose will go for around 100. hopefully 225 does it im doin it thru the mechanic, instead of the dealership, im just tired of goin in and out the shop i wanna get the parts and just get it fixed. When i first took it to the shop the saw the leak in the hose, the (lp one), and from the valve cover gaskets, the one from the gaskets is not that bad its very small, but i wanna get it done before it gets bigger.
Blacky, im really confused at this point cause i have confirmed that the lp hose has a small leak, but its def not gushing, im starting to think its the hp hose. I did flash a light,..... its so far back, i can't see it directly comming out of the hose, the leak is right behind the end of the valve cover gasket. Just to be sure im might just order a brand new hp hose as well, cause if the hose is completly recked their would be no use in repairing it. Who knows if the leak will be fixed forsure. Crazy pilot, how can i confirm if it is the rack, and what other spots maybe leakin, cause its 100% the tranny flued, i mean a bottle a day its goin nuts. Thanks again feller's wallet is empty got like 15 on the account plus i need to put down for the hose and the mechanic, so as soo as i get this over with i will let u know. For now im just tryn not to drive it too much till i get it fixed, anymore help will be great, thanks again. |
Haven't got the parts yet, hopefully Friday, but im drivin the car with this massive leak thats draining a quarter of a bottle of tranny flued a day. Is it ok for me to drive like that? I'm not usin it a lot, but i need it. Hasent done anything bad for the past 2 weeks besides constantly refilling the pump. What do u think?
