Old 02-10-2011, 04:49 PM
My dumb drive shaft disconnect questions
Do you typically remove the drive shaft before putting it on a tow dolly or after it is already on?
If before does it need the FWD fuse installed?
Is there enough room under the car to disconnect the drive shaft with out jacking it up first?
Old 02-10-2011, 05:23 PM
Re: My dumb drive shaft disconnect questions
As a, stout gentleman, I would rather drive it up onto the tow dolly, as an AWD, and then unbolt the rear end from the driveshaft.
If there is not enough space then I would put a jack under a pinch weld to make more room.
But you, as a young thin buck, should be able top do this without jacking it up further.
stout; a word we fat guys use.
Old 02-10-2011, 06:31 PM
Just unbolt it without removing it?
Old 02-10-2011, 07:01 PM
AND move it towards the drivers side and bungee it/duct tape it, to the exhaust pipe.
You can remove it if you like,
just be ready for the ATF to start spilling out.
Old 02-10-2011, 07:06 PM
Thanks.
Old 02-10-2011, 08:02 PM
Gamesy's Avatar
Gamesy Gamesy is offline
if you are taking the driveshaft off get a lid off a spray paint can and you can use it to cover the back of the transmission to keep it from spilling out
Old 02-10-2011, 08:32 PM
Ok cool, that makes sense. Gotta be specific on the internet because you never know what some idiot will do based on what you say...
Old 02-10-2011, 08:38 PM
WOW!
You must have some really thick fast drying paint!
TEE,HEE,HEE,snort!
Old 02-10-2011, 08:40 PM
What were you saying?????
Old 02-10-2011, 08:47 PM
I mostly mean that anyone on the internet can read this, not just those of us who post and stuff.
Old 02-10-2011, 08:49 PM
Wait for it......
Old 02-10-2011, 08:54 PM
? I'm not getting where you're going.
