CV Axle replacement tips
im about to replace the cv axle on the drivers side. does anyone have any hints or tips to help me out? things i should look out for or be prepared for ahead of time that the how-to may not have said? thanks!
Cal me and I can walk you through it.
Tom 304-738-0012 301-707-3437
Test the Roll Pin direction before installing. Tom was a big help too, so get him, if you can. Remember not to crank the Axel Nuts down with an air gun tho.
The Worm _______________ June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod" Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012 '05 Infinity G35 Coupe. No Mods, 33K Miles |
While this subject is going, is torque on the front axle nuts also 151 ft-lbs? I'm putting in ball joints this weekend.
Edit: Decided to move my lazy mouse hand and check the how-to's myself. Torque is 123-152 on the front.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 01-24-2008 at 08:41 PM. |
I torque them to 150.
If you're doing ball joints, you don't need to take off the axle nut? If you do, take them off, either use a new nut, or make sure that there is enough "stake able" collar to re-stake them properly.
For the ball joints, do you just remove the pinch bolt (in the knuckle), remove the three bolts in the arm, and then pound it straight out? Makes sense. Remove pinch bolt, hammer until ball joint comes out of knuckle, remove the bolts, hammer until bracket comes off. Torch as needed.
Yeah, you have the order right.
Undo the pinch bolt and pound down on the control arm to get the ball joint out of the spindle. Then undo the 3 bolts and you're done.
Easy enough. With all the rust on my car it might take a little more than some hits with a hammer, but one way or another...
If you're replacing the ball joints anyway, a pickle fork can make easy work of it.
And
Ha Ha Ha Ha........
Make sure you take a look at your "Disk Cover", behind the Rotor when you finish the job. I tweaked mine on both sides while doing the job, and ended up with the Rotor rubbing for the few miles back home. Quite embarrasing to have the car whistling from both sides because I tweaked the shields towards the Rotors while trying to get the three bolts out. Amazingly this was not a really major job when I look back on it.
You mean the dust shield behind the rotor? I don't have those anymore. 15 years of salty roads ate them. Here's the left front. While replacing the brakes I decided I didn't need it anymore and gave it a little tug. That's all it took, no prying or yanking, just a light pull.
Oooooooooooooooh my gosh! Looks like a little salt was on the roads you drive on.
Arizona uses Cinder to cut the ice on the roads here. Volcanic rock that's been ground to a somewhat course, BB size, then it's cleaned off the roads as soon as they dry up again. Hmmmm "Road Herpe's" might be a good term for what happened to your dust shield. Sick
It was suggested here a while back (I think by beav) that you can avoid the pickle and just remove the 3 bolts/nuts and push down on the control arm to avoid having to mess with the ball joints at all. I've done this every time I've done an axle and had great luck with it.
im glad we use granite out here in CO on our roads! even the used cv axle i got for 25 bucks barely has rust on it and its been sitting for years! its in amazing shape for being used though, better than the ones on my car now! haha, i might be doing this a few more times....
