Re: Fiberglass hood and hood struts
Actually it had quite a large opening in the hood, the freaking engine was sticking out.
Originally it did not have a big freekin hole in the hood.
Ok, took some measurements and the fiberglass hood is 22lbs. The stock hood is right around 45lbs.
When I did the new struts I got the GNSI 2250-90's which seem to fit pretty well. The hold 90lbs with an expanded length of 18" and a compressed length of 11" They do have struts with the same dimensions that are just weaker. They have 30lbs and 45lbs (http://www.spdhardware.com/catalog/G...20Gas%20Spring) I'm thinking I could do one of those. That would exert less pressure on the hood when closing it, but still be enough to hold it up. I'd probably go with the 30#'s. What are your thoughts?
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
