Pistons,Rods,Cams for FI Engine
Im looking to build an engine I can call reliable. The stock blocks just dont cut it with a supercharger. Does anyone have these parts anymore? LAN stopped Selling them
Re: Pistons,Rods,Cams for FI Engine
Call cp.... or any other piston company... ir gonna pay but they will make what you desire... rods... eagle or better will make up a matched mset of 6 for u... valves... brian crower
Tom |
Click the turbo project link in my sig, that should get you started.
The run down is this though: CP pistons 9:1 CR forged pistons complete with rings and wristpins - $1100 6 take-off STi rods - $100 Cometic headgaskets - can't remember, I think they are like $130 now Unless you want to rev a lot higher (which there's really no reason for) then that should do it. You can also get Eagle H-Beam rods for a reasonable price, but you will have to contact them and get a balanced set of 6. They were unresponsive to my emails though.
Arias Pistons are also available, contact Nick Arias III at atomicspeedware.
Will i be able to run my 12psi pully with that? I think I have meth injection..havent done much under the hood yet. Also headwork cams,valves,springs...I need more input on the subject please if anyone has it. Who?
Eric Rebuilt P/S pump info... http://www.subaru-svx.net/forum/showthread.php?t=50918 If your car wont start info... http://www.subaru-svx.net/forum/show...ighlight=click Last edited by SomethingElse; 03-02-2012 at 01:59 PM. |
I emailed them and asked if they had any and he hooked me up. Try to get some eagle ones first, it's the only place where I "cheaped out". I think you should definitely be able to run 12 psi with that, that's around what I'm aiming for.
I called them yesterday and they were out.
Manley makes rods too, that's what is in Jack's EG33 Impreza.
I may have found some STI rods for next to nothing. From what I read they are forged..if they come on a stock 300hp engine I think they will work just fine for my application.
OK I want to make sure I got it all...and where to get it from.
Cometic head gaskets - http://www.cometic.com ARP head bolts - ??? (required?) CP pistons - http://www.cp-carrillo.com Aluminum crank/rod bearings - ??? Rods - rallispec.com (eventually) as far as head work I think im going to rock the stock equipment. I haven't found any threads that says it wont work.
for less than $200.00 a pair.
