Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > Body Modifications
Old 01-08-2008, 06:23 PM
94SubieSVX's Avatar
94SubieSVX 94SubieSVX is offline
OOC for a while
Send a message via AIM to 94SubieSVX
Lightbulb A little something I've been working on.....
These are in no particular order but you should get the jist of what's goin' on.
bLAh
Old 01-08-2008, 06:24 PM
94SubieSVX's Avatar
OOC for a while
bLAh
Old 01-08-2008, 06:27 PM
Cooooooooooool! Did you intend to go through the front of the spoiler though?
Old 01-08-2008, 06:30 PM
Hocrest's Avatar
Hocrest Hocrest is offline
Freezepop's are Awesome!!!!
Originally Posted by 94SubieSVX View Post
[IMG]
Ducts for cooling the rear brakes??
Looks good so far
Old 01-08-2008, 06:34 PM
94SubieSVX's Avatar
OOC for a while
Yes I did.
When I started it, I got a little anxious/impatient and didn't move the wing back. That would have made it easier to make the transition to the rear window plastic pieces(I forget what they're called).
But what I did was just get a general line looking from the side, then used styrofoam to help shape it out. Then put bondo on it and shaped it out using the bondo.
What I haven't got to start yet was, I'm gonna re-locate the third brake light to inside the wing like the prototype. I'll find the pic I saw it in then post it. I'm also gonna try to make the wing have the same curve as the trunk itself. (Looking down from above the trunk, I want the wing to take that curve).
Also once all of the shaping, sanding, etc. is finished, I might put a layer of fiberglass over to strengthen it up a bit.
I'm excited I can finally work on this more, but it's only cuz my diff decided to blow up the other day
bLAh
Old 01-08-2008, 06:38 PM
RSVX RSVX is offline
Network Design Administrator
Looks nice, sanding that inside curve is going to be a B!tch!
Life is a game. Play to win.
Old 01-08-2008, 06:41 PM
94SubieSVX's Avatar
OOC for a while
Tell me about it...
I tried to a little bit, but when it's all choppy and rough like in the early pics, its hard to get a good sanding rhythm going. That's when I would whip out the grinder, but it won't fit in that tight area.
bLAh
Old 01-08-2008, 06:42 PM
I've actually had the idea of doing this bouncing around my head for a while. I think I would probably not bother using the stock wing at all and make one out of foam, then glass over it.
Old 01-08-2008, 06:46 PM
94SubieSVX's Avatar
OOC for a while
I was thinking of doing that too, but I don't have dense foam, the stuff I have would just break since the wing is so thin.
I think using the stock wing will come out pretty nice once I finish the re-shaping of the back of it.
The real killer of doing this is all the damn sanding I have to do. Just to get the one side to come out like that took me a long time. I'm guessing I'll spend around 20-25 hours just sanding with this project.
bLAh
Old 01-08-2008, 08:27 PM
All I really want for Christmas is the Show car spoiler and the side skirts.
Good show Kid!
Old 01-08-2008, 08:45 PM
SUBBYRU89's Avatar
SUBBYRU89 SUBBYRU89 is offline
Siren of the Pleiades
Send a message via AIM to SUBBYRU89
Looks good so far
I'm more judgemental at the final product, but I think it'll turn out great in the end.
Hocrest, it seems to me that those are his smugglers coves...pretty nifty when you need to hide small stuff
14.708 in the 1/4 mile pre-KillerWail
'89 XT6 Pearl White~JuiceBox (Project)
'92 SVX BoverP~Peej (Down for the moment) 1st Stage II trans installed by AWD,15 & 20 min mods,...
redlightningsvx's Avatar
Collision Refinishing Tech
that bondo gonna crack, i would have laid fiberglass strips down to form it then put a light coat of bondo over that to smooth it up.......just some ideas but looks good so far
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 01-08-2008, 09:38 PM
94SubieSVX's Avatar
OOC for a while
Originally Posted by SUBBYRU89 View Post
Looks good so far
Well I'm not smugglin grapes I can tell ya that
bLAh
Old 01-08-2008, 09:39 PM
94SubieSVX's Avatar
OOC for a while
Good show Kid!
Have you been a good boy so far this year Mr. Files??? Maybe Santa will be good in return!
bLAh
Old 01-08-2008, 09:41 PM
94SubieSVX's Avatar
OOC for a while
That's what I was worried about. And it probably will happen just from normal flex of the trunk. Now I'm thinking I should put a layer on the bondo after everything's done.
bLAh
