motor mount
Does anyone know which motor mount can replace the oil filled svx mounts?
Re: motor mount
My understanding is that your options are:
OEM SVX motor mounts "Group N" mounts for a WRX, But they have to be modified to fit. |
Re: motor mount
The SVX engine mount plates,
that the engine mounts are bolted to, have to be modified ALOT! http://www.subaru-svx.net/photos/use...svxfiles|31613
Re: motor mount
http://www.rallispec.com/prod_mount.htm
The very first product listed is the mounts in question. Google the part number and you might be able to find a better deal elsewhere, but a lot of places sell them individually instead of as a pair, so pay attention to that. You will need to use the stock SVX mount brackets, with the holes drilled a bit to accommodate the slightly differently spaced studs of the group N mounts, and ~1/4" of washers or some kind of steel plate such as in svxfiles pics. Otherwise the engine will not sit quite right.
