"big brake kits"
are there any simple cheap caliper options that will bolt on in the front for more sotopping power?
1991 xt6 eg33? 1993 gc track car |
I don't believe so, there are options, but they're not cheap.
http://svx-motorsport-accessories.stores.yahoo.net/ They have one, but it's near $3000. I know origional tom has one, but i'm not sure of it's cost. I have drilled/slotted rotors i picked up for $200, and my svx has pretty healthy stopping power. Remember, if you can get abs to kick in, it's not better brakes you need, but better tires.
Jeff,
Talk to Old Tom. I'm not sure if his kit is ready, but it will be less than $3k I've driven his car with the Big Brakes and it is a nice improvement I thought you just bought brakes for your SVX???
i did but i was wondering if any one here had done a setup like what i did with the xt6, like if wrx calipers would bolt in etc...
_________________________ VOTE RON PAUL 08! OWNER OF THE FASTEST NA SVX WITHOUT THE NEED FOR AN * BEHIND OUR RECORD! Right Bash Brother! Last edited by benebob; 08-10-2007 at 09:06 PM. |
Rotors and pads, calipers
Get yourself some slotted and drilled rotors from raceconcepts, around $200 for all four. A set of Akebono ProAct Ceramic pads, $60 a pair from TireRack. If your calipers are working normal you should have plenty of stopping power for everyday driving. I replaced all four of my calipers with NuGeon powder coated, cause mine were rusted and frozen. Brakewarehouse.com is who I got mine from. You could skip the powder coat if you wanted, cause its expensive. I bought 2 sets for both of my 96's. Fronts are $234.99 plus $120 core charge, Rears are $219.99 with $70 core charge. Those are powder coated charges only, obvioulsy non poweder coated will be much cheaper. Also replaced the brake lines with Stainless ones from Dayle at MotorsportsWarehouse, and my brakes are fantastic. If you contact brakewarehouse.com, ask for Robert Mack, he helped me with everything and is great.
http://www.tirerack.com/brakes/brake...ar=&perfCode=P
1995 POLO LSI 76K MILES SOLD |
Or...
Another option
1999 Audi A8. No more SVX's for now. |
once I get my projects in line with the built motors I will be making the move to get the 6pot wilwoods on my car... When I get my new brackets made... I will run a couple batches for people later on
Tom |
