#46
Re: 6 mt
Here's what I did. Traced out the SVX auto plate gasket then traced out the WRX gasket plate, using the top/bottom alignment nipples to line them up. Cut out holes for WRX boot nipples/auto gasket bolt things. Cut off auto gasket nipples. Sandwich WRX rubber in between aluminum and auto gasket. Profit.
'92 SVX LS Pearl White - 6mt |
#47
Re: 6 mt
I am going to unashamedly steal your invention. Kudos to you sir.
#48
Re: 6 mt
Be warned....... Getting the boot sandwiched in there was a pita. Worth it though. I also need to dremel a bit off of the left side. It touches in first.
#49
Re: 6 mt
Yea it looks a bit narrow, but I bet it does the trick.. How did you attach the rear shifter stay bushing?
#50
Re: 6 mt
Dragon, how would describe the level of in cabin noise caused by the transmission (if any)?
#51
Re: 6 mt
Cabin noise is one of those personal preferences. I would say that it cuts down on the transmission noise, but some of the high pitched whine that you can get in certain gears really can't be blocked out. It does wonders for the road noise, though. I also need to put a dab of sealant where the reverse cable comes through to seal that as well. I also need to look at getting the heat shield back in there to see if it cuts down on some of the exhaust noise coming through. I'll see if i can get some decent in car video tomorrow.
#52
Re: 6 mt
Here's a few pics of my rear shifter stay and clutch line. Working on the video.
I had my clutch line locally made. I should have had it made a little bit longer.
#53
Re: 6 mt
3 videos in different car states. I find the noise level comfortable. It is not as loud as the video portrays.
#54
Re: 6 mt
Sounds a little louder than my 5 sPeed It is a standard with actual
Gears so it will have the wine. I will post mine later if I can fig how TO get it off the camera |
#55
Re: 6 mt
keep in mind that i don't have a shift boot yet. That will help to dampen the sound.
#56
Re: 6 mt
This taken with me in 4th and in 5th at 45MPH and I am gunning it . You can see the shifter jump when I step on the gas
#57
Re: 6 mt
It wont come up????? I click on utube red square and paste the link in the {[} and nothing
Got it thanks .The vol is very high as you can hear by the voice on the GPS turn down the vol so the GPS IS NORMAL Last edited by Conn SVX; 07-03-2012 at 08:16 AM. |
#58
Re: 6 mt
you need to delete this portion from between the brackets: http://www.youtube.com/watch?v=
#59
Re: 6 mt
Hi guys,
I didnt get the shifter rubber boot , so I decided to take a standard legacy 92 shift boot. I used the original SVX shifter plate with another selfmade plate. http://s7.directupload.net/images/120713/i8a6cjmg.jpg http://s1.directupload.net/images/120713/5p5w75ak.jpg Then I used the legacy shift boot as a noise reducing boot and bolted it with the shifter plate. It covers 3/4 of the back part and the front part i covered with a plate surrounded with noise reduction tape. http://s7.directupload.net/images/120713/f8x675gr.jpg At the end, I installed the leather shift boot and the shift knob. http://s14.directupload.net/images/120713/6zin8fhm.jpg Not driven yet, but after i switched through all gears it was more quiet than before. Tomorrow, I will do a test drive greetz |
#60
Re: 6 mt
the street and transmission noise is almost gone. just little transmission whine @low rpm. very quiet at higher speed (>130kmh).
