New twin clutch
I have killed my fourth clutch in my car so I have decided to move to a stronger twin plate clutch from Ogura. It comes with a lighted fly wheel.
http://www.ebay.com.au/itm/OGURA-Rac...item1e4f1a2486 Before everyone worries that their clutch might not last I have done everything possiable to kill mine, such as towing fork lift truck that were bogged, climbing sand dunes that were almost vertical which required the car to cross the top of the dune with the two front wheel about 4 foot above the ground. When we crossed the simpson desert the clutch got so hot it welded its self to the fly wheel and didn't release till it cooled down. Also the size tyre 235 R70 16 I run means they don't lose grip on tar so the clutch and transmission take the load. Here is the clutch fresh out of the box and if it works as well as it looks then it will be brilliant. Tony Its beauty warms my heart.
Re: New twin clutch
NEW to a lot of this
What is DCCD tran? |
Re: New twin clutch
It is a transmission with a Driver Controlled Center Differential
'92 SVX LS Pearl White - 6mt |
Re: New twin clutch
Installed and not working, seems there is a issue. Have adjusted the clutch but can't get it to release. I got underneath and found that the first steel plate and clutch are releasing but the second is not backing off.
Net result is I will have to take the engine out. The reason I am taking the engine and not the gearbox is I want to look closly at how its bolted up, don't want to do a wheel aligment again and finally putting a 6 speed in off the ground when the car is on stands is a tough job on your own. Its far easier to us a motor lift. Will let you know the issue. Tony
Re: New twin clutch
Re: New twin clutch
"can't we all just get along?"
Re: New twin clutch
Yes, that thing looks like it means business.
Re: New twin clutch
Ow, my wallet hurts just looking at that!
Re: New twin clutch
Yeah I am looking at a couple Tilton clutches for when my OEM STi one goes, but would be interested to hear how this one holds up... As far as $$ goes, gotta pay to play....
Re: New twin clutch
Re: New twin clutch
