Over sensitive gas pedal?
The last couple of days I've been searching old posts to see if I can figure out something on my SVX, but so far I haven't had any luck.
Here's the problem. Since the rebuild the gas pedal has been extremely sensitive. It's fine when I first take off but when at a speed I want to cruise at, you practically don't have to touch it. The slightest pressure will make you accelerate. Anyone seen this before? I've heard people talk about having a bad throttle position sensor so I tried looking that up but it doesn't seem to be the same thing. Any ideas?
'93 LS-L named "Samantha Victoria Xavier"...Sam for short. All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter. |
Re: Over sensitive gas pedal?
Perhaps the throttle cable is adjusted too tight, without slack?
That's the only explanation I can think of.
Same here. Cables are probably too tight.
Chiketkd did a thread back in 2004 about tightening the throttle cables to remove the slack and improve the throttle response. see HERE .
Thanks, that thread does sound exactly what I'm experiencing. Perhaps when they rebuilt the engine they tightened it up? I'll play with it later today if I can get out of work early enough. Thanks again
Yep, this is also something I need to tweak before I pull my car out of storage next month. After I stripped and rebuilt my throttle body (Which I DO NOT recommend anyone do) I installed the lines a little tight. Idle is up around 900 RPM and it will roll forward quite quickly in gear.
Definitely not doing wonders for fuel economy.
