WTB: spacers for front sway bar bushings
Anyone wanting to sell or have extra spacers for the front sway bar bushings?
18" Centerline Forged Wheels, Falken Visa Z Rated Tires, Slotted/X-drilled Rotors, Steel-braided Brake Lines, Metal Master Pads. Future mods: Ram Air intake, hi-flow Cat., and drop springs. |
Re: WTB: spacers for front sway bar bushings
Do you need stock, or stiffer front anti sway bar bushings?
Sorry for not being too clear, I am looking at upgrading my front sway bar bushings with aftermarket ones since my are shot. I read here that changing them with non stock ones would require adding metal spacers to the fronts. Thanks for the help.
i didn't need nuthin else w/ my energy suspension bushings.
WFO! http://www.cardomain.com/id/Schralper "You all laugh cuz I'm different I laught cuz you're all the same." |
Energy has bushings that fit THE FRONT without modification?
What #?
Was this the part # ENS-9-5105R for the fronts? Do you have any pics as well?
Thanks bro,
the Energy ones I have don't need spacers, but do require trimming to fit into the stock SVX bushing brackets, and a notch to clear the flange on the frame rail.
On a completely unrelated note, polyurethane cuts quite easily in a milling machine.
Thanks,
I bought mine from Summit Racing <clicky>. Part number is ENS-9-5105 (followed by G (for black) or R (for red))
They do need to be notched and thinned to fit the bracket for the original bushings, and the hole has to be drilled out to 18mm. The bushings come with a bracket, but I don't think it fits the SVX's odd mounting points. Here's a picture (From svxfiles locker) of the Energy bushings installed:
