Old 01-21-2013, 02:43 AM
B 4 You's Avatar
B 4 You B 4 You is offline
#lolsvx
Two questions
My belt squeaks. I need a new one. I can NOT find it for the life of me, but someone once posted a video on here about stretch-to-fit belts. Does anyone know where I could buy these? They had a cool tool and everything to take them off. Considering I can't easily get it off, a stretch-to-fit would be ideal!
Also, I bought some new (used) rear strut mounts to replace mine. I'm 103% sure they've both collapsed. How hard is this of a job to do? Are there any how-to's? Pictures always help. I'm pretty good with mechanical jobs as long as I have decent directions, and I've got a handful of friends that could help out. I just don't want to spend 5 hours due to my lack of a lift and significant power tools and end up with no end result when I could take it to Monroe and have it done for 50 bucks.
1992 Pearl White LS
Owned since 2009
175k Miles
2005 WRX manual swap
Rear wheel drive
K-Staff front bumper
Delta Speed side skirts
JDM clear corners
Smallcar grille
Subaru XT steering wheel
Subaru XT shift knob
First bagged SVX in the world
Old 01-21-2013, 05:57 AM
Re: Two questions
Can't help much with the belt question, but I have changed my struts. The rear suspension in the SVX isn't difficult to change, just very tedious. In order to access the top mounts you need to remove the shelf behind the rear seats (Where the speaker grilles are. Whatever that area is called.). Getting that off is a bit of a puzzle. As I recall it means removing the rear seat back and cushion, the interior side panels, and then the shelf. You'll see two foam blocks, under which are the 3 bolts that hold each strut in place.
The lower mounts are almost a joke by comparison in terms of time. Jack up car, remove wheels, detach brake line bracket, remove the two large mount bolts and voila, you're done.
Usually you want to undo the lower ones first and have a helper outside the car to catch the strut as you undo the top ones.
Old 01-21-2013, 06:42 AM
Blacky Blacky is online now
Re: Two questions
There's way more than 50 bucks labor involved in the job. If Monroe actually quoted you that price by all means have them do it. 5 hours of your time is about right for the first time doing it.
Old 01-21-2013, 10:14 AM
Re: Two questions
All reasons that anything involving the interior of the car I keep far away from the hands of regular mechanics. What I'd do if you have to have the struts done at a shop is take apart the interior yourself, so they don't have to and therefore don't have the opportunity to ruin anything on the inside of the car (breaking clips, etc.) Then take the car to the shop, ready to go, and once you get it home, put the interior back together yourself. Best compromise.
As to the question about the belts, just buy a correct belt.
Old 01-21-2013, 12:20 PM
B 4 You's Avatar
#lolsvx
Re: Two questions
I've removed the entire rear interior multiple times before. I've kind of got the hang of it now. Do I need a spring compressor for the job? I can get one easily. And Icing, my tensioner pulley won't come off, so I can't exactly get a new belt on that doesn't stretch. :[
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
Old 01-21-2013, 12:44 PM
92 SVX 92 SVX is offline
Re: Two questions
Yes use spring compress you do not want the top nut flying off like a bullet.
To remove the drive belt(the one for power steering) loosen the tensioner pulley bolt as well as the slider bolt. Though the slider bolt will actually tighten to remove.
Old 01-21-2013, 12:48 PM
Re: Two questions
Why won't the tensioner pulley come off?
If you can get a spring compressor, then definitely do that. The rear springs are pretty weak, but still better to be safe.
Old 01-21-2013, 04:38 PM
B 4 You's Avatar
#lolsvx
Re: Two questions
The mechanic who used to live by me and would put tires on for me tightened my "fan belt" because it was squeaking once. He had this obsession with using 3 feet of leverage, and now I can't get the bolt off, not to mention that it's completely rounded off. He tightened the bolt that is in the middle of the pulley, not the long tightening bolt, that one works fine and does help a little.
1992 Pearl White LS
Owned since 2009
175k Miles
Rear wheel drive
JDM clear corners
Smallcar grille
