Crankshaft socket
The Subaru Part is about $75...yikes! I need the socket to position the pistons correctly.
I've looked online and came across a number of aftermarket sockets for about $15, but they need the inner diameter size of the crankshaft snout to ensure proper fitment (checked the svx manual without much luck ). |
Re: Crankshaft socket
Thanks, Keith |
It's a Subaru specific tool that locks into the woodruff key on the crank to allow it to be turned to locate the wrist pins, which in turn lets you remove them and then the pistons. Looks like this:
What I've always done to rotate the crank is just install the crank pulley bolt finger tight and use it to turn the whole assembly. Just keep turning to the right, unless there's something very wrong with your rotating assembly it won't tighten up much turning and can easily be snapped loose after.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 11-04-2011 at 10:05 PM. |
Same here.
Dito! That was the reason for my confusion. why would it be necessary. I always just do it the same way. Just wanted to make sure I wasn't missing something there! Thanks!
Keith |
