Stance GR+ done
Well after getting inspired by a few of the other members here that used the stance coilovers I decided to follow...
The lack of communication and updates with amr suspension had me a little gun shy and the money i save with the sti suspension will help offset the cost and give me an excuse to buy a few new tools. I also bought the 05/07 suspension with 7k/5k spring rates $1080 shipped I just searched and I need to thank SMC and crazypilot for taking the time to post their swaps !!!
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. Last edited by jman050; 04-04-2013 at 08:03 PM. |
Re: Stance GR+ done
I lowered the front around between .75 and 1 inch which gives me a stance I am fairly happy with and the control arms are still even. The strut body bracket needs to be widened to atleast 28mm to fit the svx not a hair less....or dont even think about it.
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. |
Re: Stance GR+ done
I also used QS components for my endlink making. I ordered enough for my to do my rears as well so now im just waiting on dayle and the machine shop to send out the rear sway bar I ordered.
Overall I am very happy with the performance. I am completely stable at stupid fast speeds that I havent seen in forever. I know i may be lectured but I just had to test it. And with the hankook evo v12 tires the overall handling is excellent I just need to stop procrastinating the rear diff bushings.
Re: Stance GR+ done
Looks very good. And it works well for you that is the important thing.
Re: Stance GR+ done
Awesome, looks great. Very clean. And just the right height too. About the same height as I have mine at in fact.
Did you machine the top plates yourself and put the studs in?
Re: Stance GR+ done
Yea I did all the work myself probably took me 15hours total but I was building the end links at the same time. There was at least 8 hours of grinding and measuring but I was being very careful
Re: Stance GR+ done
Where did you get Stance Coilovers for $1080?!?! Also, what did you do about mounting the front sway bar?
1992 Dark Teal LS-L w/ 165k+ miles (traded ) Mods: Power Slot front rotors, polyurethane sway bar bushings, window scratcher fix, SPD hood struts, Outlaw Engineering phenolic spacers, Bontrager Works 22mm rear sway bar, R-134a conversion, 93 Legacy SS 5 speed swap, Ceika coilovers, ARP head studs 2001 Black Toyota Sequoia (hauler/daily) 1992 Blue Toyota Cressida (drift car) 1992 Red Toyota MR2 (weekend/track day car) |
Re: Stance GR+ done
Glad your happy with your new suspension
Re: Stance GR+ done
I like it a lot, this looks like machine work i could handle, though wouldnt sti spring rates be a bit soft on our heavier cars?
edit: nvm, saw that they were custom ordered.
1992 SVX Pearlie: AmsOil signature synthetic 10w40 and Ea15k20 filter, Cobb crank pulley, Outlaw Engineering spacers and tb bypass, LGT 5spd, Slotted Crossdrilled rotors and ceramic pads, 11:1 compression, EGR delete, Port & Polished heads, SaikoMichi catch can, A/c delete. |
Re: Stance GR+ done
Looks great! I still love my Stance coilovers, the car feel glued to the road. How many hours was the install? Using the 05-07 STi was smart, the lower mount is already much closer to fitting than my 02-07 WRX. I believe Stance sells the tube portion of the lower mount as a fabrication part. If/when I redo mine in the future I'll buy those and add my own flanges to perfectly match the SVX knuckles.
Edit: Yep, here. But at $229/pair! That's a little outrageous if you ask me. See his last picture, looks like he used a beefier version of what I did.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 04-05-2013 at 05:50 AM. |
Re: Stance GR+ done
Have you just done the front?
Bill
Re: Stance GR+ done
No I did the rear. The picture with the drill press is the rear mount with the new stud hole.
Re: Stance GR+ done
EBay Texas motorsports store I believe the sellers name is txautoplex
[SIGPIC][/SIGPIC] STi BBS wheels,legacy gt 4.44, 3" catback exhaust, Stance GR+ 7k/5k, QS Teflon adjustable endlinks, Hankook EVO 245/40/17, 95-LS escaine seats, GC8 V7 steering wheel, JDM clear corners, small car clear lenses, Alcyone badge, JDM rear taillight, 97 grille, stevesby bumper, PWR radiator, Perrin Crank pulley, Urethane Swaybar bushings, urethane diff bushings, DDM 6k 55watt lows and 4500k 35watt fog lights; $15/15min mod, Motorsport whs 22mm rear swaybar, QC shift kit, ToMyx intake, z32 aluminum calipers 13" rotors, nitrous express proton + wet kit. Last edited by jman050; 04-06-2013 at 04:04 PM. |
Re: Stance GR+ done
Does anyone know if the sti brake lines are compatible. I really don't like the how the svx lines are mounted
Re: Stance GR+ done
What's the difference between how they're mounted in the STI versus the SVX?
Most likely the fitting sizes are the same at both ends of the lines, but the lengths may not work out right.
