Old 03-19-2012, 07:37 PM
kwren's Avatar
kwren kwren is offline
Re: One other question.....Struts
Originally Posted by North Ursalia View Post
It's a tale worthy of a Norwegian Saga at the moment:
http://www.subaru-svx.net/forum/showthread.php?t=58974
Takes us to...
http://www.ebay.com.au/itm/COILOVERS...item19cc1a9f1f
All gone...
Keith
Old 03-19-2012, 09:14 PM
North Ursalia North Ursalia is offline
Hi Mr. Penguin!
The Saga is towards the end of the thread- the auctions have been down for quite some time.
Old 03-20-2012, 12:22 PM
kwren's Avatar
thanks
Keith
Old 03-20-2012, 01:40 PM
wohnson89's Avatar
wohnson89 wohnson89 is offline
At home in the flatland
I found something interesting in this topic, Dynomatt the maker of the svx rally car used DMS shocks in his car, and if I understood him correctly, they went in with not much work.
http://www.subaru-svx.net/forum/show...t=34904&page=8
there is alot about them right around post 100
1992 Subaru SVX LS-L Pearlie
1989 Mazda RX7
2005 Mini Cooper S
Old 03-20-2012, 02:10 PM
halistan's Avatar
halistan halistan is offline
Grand Poo-Bah
Send a message via AIM to halistan Send a message via MSN to halistan Send a message via Yahoo to halistan
Interesting find! Although, after looking at some of the pics he posted after they were installed it looked like the height of the car jumped up a bit. That's no bueno
'93 LS-L named "Samantha Victoria Xavier"...Sam for short.
All new and improved custom built engine with forged internals, lowered compression, upgraded cams and a stage III supercharger. AMR Engineering struts, Custom exhaust --All 3 Subaru cats removed, and replaced with 2 high flow mustang cats-- Cross-drilled & Slotted rotors, steel braided brake lines, bypassed stock Tranny cooler replaced with aftermarket B&M super-cooler, and a K&N drop in air filter.
Old 03-20-2012, 02:28 PM
Hi Mr. Penguin!
I don't know if you've ever priced DMS struts but even the 40mm gold for the street are into Aragosta territory.
Old 03-20-2012, 02:37 PM
halistan's Avatar
Grand Poo-Bah
Oh, no I've never priced them. I had no idea they were up in that range. What makes those other struts that expensive??? I mean, if you can get a set of koni's for $1000 but Aragosta's for $3~$4k...that's a pretty big margin for a part that I can't really comprehend being that different
Old 03-20-2012, 02:48 PM
The Koni's are just inserts.
The Aragosta's are struts, springs, mounts, easily adjustable from under the car.
And just adjust them and install them.
No cutting welding, painting that you need to do, or have done with the Koni's.
Old 03-22-2012, 04:34 PM
halistan's Avatar
Grand Poo-Bah
Originally Posted by Crazy_pilot View Post
So I just emailed Stance, the maker of my coilovers, to ask if they would consider developping a system for the SVX based off the WRX one they already sell. Obviously they will look at it from a business perspective, but hopefully they'll be open to the idea. The bits needed to fit the SVX aren't much, just a machined aluminum camber plate and the lower mount. I'll report back if/when I get an answer.
So any word on this yet? Inquiring minds want to know
Old 03-22-2012, 04:51 PM
No replies yet, but that's not something that surprises me. If it's taking them several days to get back to me it's either because they're actually looking into it and are taking their time, they're already super busy, or they're blowing me off. Time will tell.
Here's the email I sent them:
Hey guys,
Bit of an off the wall question, but would you ever consider developping a coilover system for the Subaru SVX? I'm an active member of the main owners group, and one of the biggest problems facing us right now is a lack of suspension parts. It seems that the OEM replacements have sat in storage for 15+ years and blow out in a month or two of use. In the past many have had custom coilovers put together using Koni inserts and Ground Control springs on the stock strut bodies, but Koni has discontinued the inserts.
The reason I'm contacting you guys is that I installed a set of GR+ coilovers in my SVX 18 months ago. It took some work, but I was able to get a set meant for a 2002-07 WRX to fit, and the function has been flawless. Given that I was able to do this, would it be feasible to develop a system for the SVX based on the WRX setup you already have? The upper and lower mounts would need to be modified, but the body is perfect in it's current form. The link below shows the thread that documents my installation:
http://www.subaru-svx.net/forum/show...t=41831&page=3
If someone could look it over and let me know what you think I'd be very grateful. There are many owners who love their cars and are faced with the shortage of replacement parts, and it will be a terrible shame to see these cars being scrapped because of this.
Thanks,
Old 03-22-2012, 05:31 PM
halistan's Avatar
Grand Poo-Bah
You da man Chris!!
Old 03-22-2012, 06:47 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Maybe they havent gotten back to you because their accounts aren't accepts yet
Old 03-23-2012, 03:50 PM
Got a reply! I'm going to start a separate thread to up the visibility.
Old 03-23-2012, 05:30 PM
Here's the new thread: http://www.subaru-svx.net/forum/showthread.php?t=59483
