Want to do a tuneup. Suggestions?
My car is running a little rough before it gets warmed up, and I have a few leaky seals and the oil pressure sensor is leaking as well. I want to do a good tune up and replace the seals while I'm at it.
So I'm wondering what I should do for the tuneup. This is what I've thought of so far: 1. Plugs (what kind?) 2. plug wires 3. should I do coils or would it be obvious if one was bad? EDIT: just looked at coil prices. I won't be doing those unless necessary! 4. clean TPS 5. already changed fuel filter not too long ago 6. Air filter 7. Clean injectors 8. What else?? Since I need to replace the rocker/valve cover gaskets, I'm thinking it will be easier to just pull the engine. That will make changing the plugs easier and then I can do the main seal at the same time. I did a search for what to do for a good tuneup, but couldn't find much so that's why I'm asking Any and all suggestions welcome (doesn't mean I'll listen, though ) Thanks!
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 Last edited by SVX8588; 05-10-2012 at 05:35 PM. |
Re: Want to do a tuneup. Suggestions?
Remove the airbox and snorkus. Remove the airbox mounting bracket. Remove the battery. Pull the coils, using a 12mm ratcheting box end wrench. Spend some quality time "expressing yourself". Use words like;!@#$%^ and &*()_!!! You will feel better for it. Apply salve to your burnt hands, and wait for the engine to cool. Remove the valve covers using a 1/4" drive ratchet and a short 10mm socket. A 10mm ratcheting box end is usefull as well. Once the valve covers are removed the plugs are now a 18-30 minute job! Use anti-sieze on the threads. Now spend the rest of the day cleaning up the 17 gallons of oil that has covered your garage floor. Golly this has been fun!
To clarify, he means use anti-seize on the threads of the spark plugs. This is important.
uh oh....i didnt know this (edit) about the anti-sieze that is
i changed mine like 2 years ago....are they gonna be a b!tc# and a half to change again?
Jared 1992 dark teal SVX LS Last edited by LastSVXintheChi; 05-11-2012 at 03:11 PM. |
It is better to change them out sooner than later. Be gentle.
not to post to disagree but i wouldn't put anti-sieze on the plugs. if torqued properly they should be no problem to remove next time.
Shows how much I know...
So the coils are mounted directly on the plug and the wires that go to the coil don't need to be changed? (unless they're broken obviously) I'm used to working on stuff with cast iron heads and distributor caps and stuff
Glen SOLD - 1992 LSL 180K #8588 with svxfiles' all aluminum radiator; Wolf's head synthetic ATF in tranny and power steering; lighted power mode switch; Mobil 1 10W30 motor oil with Bosch 72158 filter; ACDelco A975C air filter; Valvoline synthetic 75W-90 gear oil, Optima BlueTop battery 2002 F550 74K SOLD - 2000 F450 215K 1987 BMW 535i 209K 1999 Yamaha SRX 700 |
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
On an OBD1 system, like the 1992-1995 SVXi,
it is best to have a second responsible person to help. Have the other person in the drivers seat, have them start the engine, (WHEN TOLD!) Have them set the parking brake, hold the foot brake, put the car in a forward gear, and to watch the tachometer. With the engine running disconnect the fuel injector connectors, one at a time to determine which cylinder is not making a differance. This only works if the engine has a miss at the time that you are testing it. The ones that make the most differance should have good coils at time of testing. This is the easiest method IMHO.
Since its most likely warm where you are
you could pressure wash the engine at a car wash. This will usually show up a failing coil. However make sure that you stay away from the coils on a wet, running engine, BECAUSE A 50,000 VOLT COIL/STUNGUN CAN KILL YOU, if powered by a big 12 volt system with a giant battery, helped along by a 90 amp alternator!
