possibility of awd conversion
I was wondering what parts things need to be done to make the FWD's to AWD and if it would be worth doing?
http://www.subaru-svx.net/forum/show...t=convert+ls-l
http://www.subaru-svx.net/forum/showthread.php?t=31966 Basically, AWD tranny, driveshaft, rear diff, axles, rear subframe, whatever other rear suspension parts are different. Probably an AWD trans control unit (TCU) and all the wiring needed to connect things. I'm sure I'm missing something though.
Chris 92 Ebony Mica LS-L "A Rolling Restoration": 223,250 KM - Sleeping 2007 STi 6MT, Stance GR+ coilovers, PWR Rad, JDM hood badge, svxfiles 6000K HIDs, JDM Clear Corners, $15/15 min mod, $20/20 min mod, Energy Swaybar Bushings, Hella Supertones horns, Gold STi BBS rims, Group A lightweight crank pulley, A/C system removed, Custom header-back exhaust, Hybrid carbon/metal rear sway bar, restored headlights with CCFL halos 2008 Subaru Legacy Spec B - Diamond Grey Metallic - Sold 2020 Ram 1500 Longhorn - Red Pearl Last edited by Crazy_pilot; 08-18-2007 at 09:15 PM. |
It isn't too hard to do as you'll read. I have most of the parts to do it with, So just let me know if I can help with anything if you decide to do it.
The bigger issue is not the wiring in the trans itself... It is the wiring going from the TCU to the fusebox and then back to the TCU for the FWD fuse and whatnot... An mt fwd-awd swap is simple and very bolts basic. Not impossible and not even that hard... if you are good with a schematic and don't mind running some wiring
Tom |
I just made a harness and put it in the left kick panel when i did it, it isn't that hard at all really. I spent alot of money on bolts, though. But then again, I bought factory ones.
If you're going to have the tranny out, you might as well just swap to 5MT as well....
