Completion of the Stage III 6-speed
The 6-speed conversion has started.
The FWD sadly requires a little extra work. The rear subframe doesnt have the mounting points for the rear. here's a few pictures. Rear subframe Under Rear Interior (I need to clean under the seats a little more often) |
Looks like you may need some upgraded bushings for the rear differential
Seems you've got a good start on your conversion there!
swap is comming along very well. Still need a couple things but I am doing what I can with what I have. BTW Mike, the 5mt starter will work with the 6speed trans so that means a wrx starter will work as well..... Not sure about the legacy starters etc.... I will see if that guy still has his for sale.... $35 you cannot beat. Still need a set of rear axles for an Sti if anyone has them...
Tom |
Will it be at Reading?
____________________________________________ 95 LS-i Red, 31,xxx; bone stock for now; Daily Driver 94 LS-i Emerald Pearl, 106,xxx,; 246 whp; Tomyx snorkus and HKS Cold air intake; PWR aluminum radiator, silicone hoses; Inline thermostat; enhanced coolant routing; external power steering and oil coolers; Phenolic intake manifold spacers; 2004 WRX 5 speed transmission; ACT Clutch Kit, Heavy Duty Pressure Plate, Lightweight flywheel, performance disc; Group N motor mounts; ‘07 WRX 4-pot front calipers, cryo-treated slotted Tribeca rotors; Hawk HPS ferro-carbon pads; Frozenrotor rear slotted rotors; SS brake lines, Axxis Ultimate pads; Rota Torque 17x8 wheels; 245/40-17 Bridgestone RE01-R's; Koni inserts with Ground Control coilovers, Eibach springs; K-Mac camber/caster adjustable strut mounts; Urethane swaybar bushings; Bontrager rear sway bar; Urethane differential bushing; Custom Whiteline adjustable rear lateral links; Outlaw Engineering forged underdrive pulley; custom grind Web intake and exhaust cams (11 mm lift, 250° duration); solid lifters; CP custom aluminum forged 11 to 1 pistons, Brian Crower coated SS intake & exhaust valves; Brian Crower upgraded springs w/ titanium retainers; NGK sparkplugs; RallyBob (Bob Legere) ported and polished cylinder heads; Eagle H-beam rods; ACL Bearings; Cometic Head gaskets; ARP head studs & fasteners; Hydra Nemesis EMS; Wideband O2 sensor; 740cc Injectors; Walbro 255lph fuel pump; Upgraded WRX starter; Equal length SS headers (3 into 1); dual Magnaflow cat converters; 2 into 1 into 2 SS exhaust with Bullet muffler; OT Fiberglass hood; Oil pressure gauge; Programmable shift light, 2017 Subaru Forester XT, metallic dark gray, 29,xxx 2005 Porsche 911 Turbo S Cabrio, 24,xxx 2006 Subaru Outback LL Bean, 166,xxx sold 92 LSL Dark Teal, Smallcar Shift Kit - sold |
Whoa cool. I was wondering what you were doing since the thing went boom.
Yes it will be at Reading as long as Mike can make it there. With any luck I will have the parts to finish it by next weekend. My source for a 3.90 R160 failed so now I am frantic trying to find R180 axles. Starter should not be an issue as the 5mt starters are a dime a dozen... Loading pics, will be up shortly
Tom |
R180
AWD vs FWD subframe Clutch master mounted Clutch and brake pedals mounted Group N motor mounts to lower engine 1/4"(hood clearance issues) Couple X-member shots(not finished, I am letting it cool as we speak) Motor mounts installed Just a tranny shot Enjoy! I am back to work Tom |
Tom,
Nice, very nice!! Seems that we now have the "Tom Team" .... See Tom J. for 5/6 spds....See Tom K. for 4.44 Autos -Bill
Tom:
That looks terrific. Can't wait to see it in person.
X-member is finished and prepped for paint... Now onto the shift linkage
Tom |
Tom your like a ****ing machine.....god bless you man
1993 25th Anniversary Edition # 156 of 301 ~ 121, 488 miles ( SOLD TO svxfiles 8/6/06) 2006 Subaru Impreza 2.5i....5spd - My daily driver 2006 Subaru Legacy 2.5i -7k miles..Mom's daily driver 2,543 Member of the SVX World Network |
Ok, quick post before I go to work. Shift linkage has been tacked... all 4 peices are ready to be fitted. Once I know they are right... it is off to the races with the rest of the car. I will try and take more pics tonight but cannot promise anything. Mike, looks like all we will be waiting on this week is parts as I should have it "mostly" done tomorrow
Tom |
And I know your gonna let me take it for a spin at Reading....right Mike???
92 SVX #772 140k 6speed, ECU Tune stage II, Koni/Ground control, 3,270lbs. 91 Legacy Turbo 5spd. FMIC, crappy stock turbo, ACT clutch. 78 BRAT (New toy) (Soon to be EJ22T powered) 90 240 SX. RB25 powered!! DRIFT!!!111!!! (GF's car) To many cars to spend time on teh web! |
Your hands are never goingto get clean now Tom!
Awesome work buddy. Looks like you're the the man on the East Coast for 5/6 spd swaps!!!!!!
