Old 04-18-2011, 06:19 PM
msvx95's Avatar
msvx95 msvx95 is offline
It's just a phase
Alternative option to replace PCV
The method using the 19mm crow's foot was a bear of a task tonight. I got the pcv valve off but I found a better way to put the new one back on.
Considering I'm replacing the air idle control valve anyways, I removed the throttle body from the intake manifold. This gave me room to use a 19mm deep 6pt. socket by reaching my hand through the back under the intake manifold where the TB is mounted and easily placing the socket on the valve. The wire harness makes it a bit tight but it can move slightly and the hose that connects to the valve can be moved out of the way.
I'm not sure if anyone does it a better way without removing the intake manifold, but this was just my experience.
1995 Subaru Svx L / AWD
Old 04-18-2011, 06:38 PM
Re: Alternative option to replace PCV
That is actually an excellent idea. I think most people are afraid of having to remove and put back the lines going to the intake and throttle body, but once you've done it a couple times, it's easy.
Old 04-18-2011, 07:58 PM
Any pictures and directions?
Old 04-18-2011, 08:10 PM
msvx95's Avatar
It's just a phase
No I should have, but actually I can take some pictures tomorrow before I put the throttle body back together. I did place the hose back on the PCV valve but I can position where the socket would be when attempting this.
Old 04-18-2011, 08:13 PM
msvx95's Avatar
It's just a phase
Yes I can do this quick and easy now...BUT considering this is the first time I replaced the PCV valve, guess what happens....as I removed the hose (not sure the name of it) from the top of the throttle body where it snakes it's way into the intake chamber, the hose split at the end.
I looked to see where the hose routes and I cannot see how to replace this hose because I'm unsure where it connects under the right side of the intake manifold.
Has anyone replaced this hose without removing manifold?
Old 04-18-2011, 08:28 PM
I managed to change the PCV with just a standard open ended 19mm wrench. *shrug*
Old 04-18-2011, 08:30 PM
msvx95's Avatar
It's just a phase
From above or below?
Mine probably was never changed..I ran out of geometry options when trying from above...also I kept dropping the new valve when trying to start the threads...then I figured up from the bottom is the most sensible way
Old 04-18-2011, 08:44 PM
Cam Cam is offline
That hose connects to one of the solenoids...IIRC. It can most likely be replaced with the throttle body off, but it would be a PAIN.
Cam
'92 Ls-L Dark Teal
11:1 CR ECUTUNE pistons
ECUTUNE STAGE 2AV1 ECU
Z32 MAF/SR20DET injectors
Balanced & Blueprinted
Old 04-18-2011, 09:29 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
You can use this.
Old 04-19-2011, 08:52 AM
Mike621 Mike621 is online now
Or...
Just pull the manifold with the fuel stacks attached and replace all those cracking vacuum hoses and aging gaskets.
Old 04-19-2011, 02:48 PM
msvx95's Avatar
It's just a phase
yes I should really replace everything....Dannmarr, you forgot to place angles on those dimensions or at least overall length and width as references ...LOL
Old 04-19-2011, 06:10 PM
msvx95's Avatar
It's just a phase
I took a few pics today. With the throttle body removed I have a 19mm socket pictured near the valve. My arm reaches in from behind where the IACV would be. I hope this is clear for those interested.
Old 04-19-2011, 06:12 PM
msvx95's Avatar
It's just a phase
So I did manage to split the end of this hose.....luckily for now electrical tape is holding.
What is the size of hose I need to purchase? I will probably cut this one and use a small hose fitting to join two pieces together.
Old 04-19-2011, 06:44 PM
http://www.subaru-svx.net/forum/showthread.php?t=56285
You may find this useful.
Old 04-19-2011, 08:58 PM
Huskymaniac's Avatar
Uses the ignore feature
Crazy thought. Is there a device one could screw in place of the PCV which would allow a hose to come out to a much more accessible location so that one could place a PCV valve in this hose and replace it easily should it be required again some day?
Manifold>PCV--------------------->
Manifold>Adapter------>PCV-------->
Tony
