Alternative option to replace PCV
The method using the 19mm crow's foot was a bear of a task tonight. I got the pcv valve off but I found a better way to put the new one back on.
Considering I'm replacing the air idle control valve anyways, I removed the throttle body from the intake manifold. This gave me room to use a 19mm deep 6pt. socket by reaching my hand through the back under the intake manifold where the TB is mounted and easily placing the socket on the valve. The wire harness makes it a bit tight but it can move slightly and the hose that connects to the valve can be moved out of the way. I'm not sure if anyone does it a better way without removing the intake manifold, but this was just my experience. |
Re: Alternative option to replace PCV
That is actually an excellent idea. I think most people are afraid of having to remove and put back the lines going to the intake and throttle body, but once you've done it a couple times, it's easy.
Any pictures and directions?
No I should have, but actually I can take some pictures tomorrow before I put the throttle body back together. I did place the hose back on the PCV valve but I can position where the socket would be when attempting this.
I looked to see where the hose routes and I cannot see how to replace this hose because I'm unsure where it connects under the right side of the intake manifold. Has anyone replaced this hose without removing manifold? |
I managed to change the PCV with just a standard open ended 19mm wrench. *shrug*
From above or below?
Mine probably was never changed..I ran out of geometry options when trying from above...also I kept dropping the new valve when trying to start the threads...then I figured up from the bottom is the most sensible way |
A PITA no matter the *shrug*
LS-L 92 black top silver bullet-Turned into a 2005 Jeep TJ Unlimited 2012 Outback 3.6R Limited! |
You can use this.
Or... Just pull the manifold with the fuel stacks attached and replace all those cracking vacuum hoses and aging gaskets.
1991 SVX L JDM |
