Old 07-08-2012, 07:17 PM
Wheel balance weights
I feel kind of dumb asking this, but what is the best way to remove the wheel balance weight so that they can be reused?
Old 07-08-2012, 07:36 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Re: Wheel balance weights
Stick-on or clip?
Old 07-08-2012, 08:12 PM
Stick-on or clip?
Clip on. I see there is a special tool for them, but I am guessing they can be removed other ways. I want to mark the wheels then put them back on.
Old 07-08-2012, 08:28 PM
Chuckls's Avatar
Designated Asshole
Why are you wanting to remove them? You said "to mark the wheels and put them back on" I'm assuming you're doing some sort of tire repair, or something?
Old 07-08-2012, 08:36 PM
Pretty sure wheel weight hammers are pretty cheap. It's the proper tool.
(assuming you're talking about the hammer-on outside weights and not the stick-ons.)
Old 07-08-2012, 08:39 PM
Or painting them.
The wheel weight pliers make it super easy (I should know, worked in tire shops for 3 or 4 years). I've honestly never had to remove a weight without that tool though. If the tire's off it's easy, just get a screwdriver against the back of the tab and give it a few taps with a hammer. With the tire on I'm having a hard time imagining something that doesn't also risk scratching the wheel. Needle nose pliers perhaps, or maybe the screwdriver/hammer trick.
Old 07-09-2012, 12:28 AM
odepaj's Avatar
odepaj odepaj is offline
Killer of threads
Originally Posted by Crazy_pilot View Post
Or painting them.
This.
Needle nose pliers will be the easiest without having the correct pliers. It's gonna be a pain though.
-Dustin
Old 07-09-2012, 05:06 AM
In that case I'll order the tool, and yes they are being removed for painting.
Old 07-09-2012, 05:26 AM
Blacky Blacky is online now
If you are painting the wheels, putting the weights back on is going to scratch the paint. I would have them rebalanced with stick ons on the back side out of site.
Also if you ever drive it in the winter nasty corrosion sets up between the rim and weights because of the dissimilar metals.
Old 07-09-2012, 05:33 AM
THIS. The ones that go on the edges look so ugly. Find a shop that has the stick-on ones to re-balance them using those. You don't want to make them look all nice with paint and then take a step back with those wheel weights.
Old 07-09-2012, 06:17 AM
The weights are on the back side of the wheels or else I would get them rebalanced.
Old 07-09-2012, 09:40 AM
subeman90's Avatar
Soobologist
I do this too when I am at a shop having my tires mounted. Hate looking at those ugly things.
15 OBW premium w/eyesight
