My dumb drive shaft disconnect questions
Do you typically remove the drive shaft before putting it on a tow dolly or after it is already on?
If before does it need the FWD fuse installed? Is there enough room under the car to disconnect the drive shaft with out jacking it up first?
Re: My dumb drive shaft disconnect questions
If there is not enough space then I would put a jack under a pinch weld to make more room. But you, as a young thin buck, should be able top do this without jacking it up further. stout; a word we fat guys use.
Just unbolt it without removing it?
AND move it towards the drivers side and bungee it/duct tape it, to the exhaust pipe.
You can remove it if you like, just be ready for the ATF to start spilling out.
Thanks.
if you are taking the driveshaft off get a lid off a spray paint can and you can use it to cover the back of the transmission to keep it from spilling out
Ok cool, that makes sense. Gotta be specific on the internet because you never know what some idiot will do based on what you say...
What were you saying?????
