Old 07-13-2012, 06:00 PM
Wow our cars are getting closer to alike all the time.
Old 07-13-2012, 08:04 PM
trying to diagnose a weird vibrating noise ,
thought it was something in the gearbox
booked it into a trans shop ,
got half way there ,
and CLUNK , TING THUD TING THUD TING THUD TING THUD
called the nrma (australian AAA)
luckily it happened literally a mile and a half from my dads house
got it towed back (on a full size trailer )
jacked it up and had a look underneath it
the front uni joint snapped its way out of the uni holdy bit
Old 07-13-2012, 08:12 PM
I have a carbon fiber hood in the garage that agrees with you.
Old 07-13-2012, 08:16 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Your storage is looking cleaner than last time
Old 07-13-2012, 08:51 PM
MUCH cleaner. Ask nate. I spend a whole night moving stuff back and forth between the garage and the storage room. Made a nice little work area. Actually it's quickly filling up with stuff again.
Old 07-14-2012, 10:58 AM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
I just finished removing the intake manifold. I left the throttle body on. Took about 3 hours total. It's not that bad with the right tools. The only issue I had was removing those damn plugs (fuel injector harness & the main wiring harness) from the brackets. I found extra hoses laying on top of the engine, broken hoses that were taped up and a missing hose with a broken nipple on the solenoid valve. This is probably the only time I'm doing this, so I'm replacing all the hoses. Everything is hard a brittle. Total cost with the solenoid is around $185. Thanks for the "how to" document!
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 07-14-2012, 11:47 AM
redlightningsvx's Avatar
Collision Refinishing Tech
did you replace the fuel rail o-rings also? there's 3 total
Seth
Past subies:
96' Legacy Outback-TOTALED
98' Forester L -Totaled
Other toys:
06' B9 Tribeca-Stock
1982' Yamaha xj650 Maxim
Old 07-14-2012, 10:10 PM
dannmarr's Avatar
I work for my SVX
Actually, the 3 hours was to remove it only. Yes, I did order three O-rings. I was unable to remove the short fuel hose on the passenger side, so I remove the pressure regulator, The O-ring for the pressure regulator is part number 16699AA000.
Subaru SVX for fun
Old 07-14-2012, 10:35 PM
Originally Posted by dannmarr View Post
I just finished removing the intake manifold. Thanks for the "how to" document!
I need to do this sometime. I'm pretty sure it's never been done on mine.
Old 07-15-2012, 12:04 AM
92 SVX 92 SVX is offline
If you do make sure you have plenty of vac hose as the original is quite brittle after all the years.
Old 07-15-2012, 01:22 AM
20ft was enough for me to do all the intake tubes, the washer tubes, and the cruise control lines.
Seth
Past subies:
Other toys:
Old 07-15-2012, 10:02 AM
dannmarr's Avatar
I work for my SVX
While I have mine apart, should I clean it or something? What should I use?
Subaru SVX for fun
Old 07-15-2012, 01:30 PM
Clean the inside of the manifold with a lot of carb cleaner and clean the passages well. Also degrease the top of the motor to clean it while its off
Seth
Past subies:
Other toys:
Old 07-15-2012, 02:25 PM
dannmarr's Avatar
I work for my SVX
How about the cavities (openings) where the fuel injecters/lifters are? Or should I do the seafoam stuff after all is reconnected?
Subaru SVX for fun
Old 07-15-2012, 02:35 PM
Dont dump anything in those. Wait till everythings back on and then sea foam it.
Seth
Past subies:
Other toys:
