#1306
Wow our cars are getting closer to alike all the time.
#1307
trying to diagnose a weird vibrating noise ,
thought it was something in the gearbox booked it into a trans shop , got half way there ![]() and CLUNK , TING THUD TING THUD TING THUD TING THUD ![]() ![]() called the nrma (australian AAA) luckily it happened literally a mile and a half from my dads house ![]() got it towed back (on a full size trailer ) jacked it up and had a look underneath it the front uni joint snapped its way out of the uni holdy bit ![]() |
#1308
I have a carbon fiber hood in the garage that agrees with you.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#1309
Your storage is looking cleaner than last time
http://i840.photobucket.com/albums/z...93705d9zzz.png |
#1310
MUCH cleaner. Ask nate. I spend a whole night moving stuff back and forth between the garage and the storage room. Made a nice little work area. Actually it's quickly filling up with stuff again.
#1311
I just finished removing the intake manifold. I left the throttle body on. Took about 3 hours total. It's not that bad with the right tools. The only issue I had was removing those damn plugs (fuel injector harness & the main wiring harness) from the brackets. I found extra hoses laying on top of the engine, broken hoses that were taped up and a missing hose with a broken nipple on the solenoid valve. This is probably the only time I'm doing this, so I'm replacing all the hoses. Everything is hard a brittle. Total cost with the solenoid is around $185. Thanks for the "how to" document!
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. |
#1312
did you replace the fuel rail o-rings also? there's 3 total
Seth 94' Barcelona Red w/ Tricoat black 2-tone AWD Ls -Sold Mods:AWD conversion/4.44 swap by Budfreak, Custom red interior lights, Custom Satin black dash, Power mode switch, Cold air intake, Permecool tranny filter,Sony xplode 10" sub, Sony xplode 1000w amp, Blitz in-line driver, DDM Tuning 6000k HID's, New paint job/body work by me, 97' Grill, QC shift kit, 17'' MB Motoring rims, 15&20 min mod, front & rear urethane swaybar bushings, Custom fiberglass sub box, Custom red led a/c control unit, perrin lightweight crank pulley, Black wrinkle finish powdercoated intake manifold w/ clear hoses , 02' outback heated/power black leather seats Soon to come:Fiberglass hood, upholster ALL suede to black leather Past subies: 92' Pearl White/black top LS-L-SOLD 96' Legacy Outback-TOTALED 99' Legacy Outback Limited 30th anniversary edition-TOTALED 98' Forester L -Totaled Other toys: 99' Forester S -WRX brake upgrade, soon an 04 wrx motor swap 06' B9 Tribeca-Stock 1982' Yamaha xj650 Maxim Mods: work in progress |
#1313
Actually, the 3 hours was to remove it only. Yes, I did order three O-rings. I was unable to remove the short fuel hose on the passenger side, so I remove the pressure regulator, The O-ring for the pressure regulator is part number 16699AA000.
Father of 5 sons and 1 daughter Subaru SVX for fun Hyundai Veracruz for the wife. Susuki SX4 for my older son Ford Ranger for work Mercedes Benz Sprinter for vacation trips, EZ GO Golf cart for driving kids around gated community. Last edited by dannmarr; 07-19-2012 at 05:25 PM. |
#1314
I need to do this sometime. I'm pretty sure it's never been done on mine.
1992 LSL ebony pearl 171k - Thank you Ron Mummert Reading Box of Wine Car 1997 Lsi 2007 WRX 5-Speed Manual, Gloss Red Vinyl Wrapped, Brz Seats 189K ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#1315
20ft was enough for me to do all the intake tubes, the washer tubes, and the cruise control lines.
#1317
While I have mine apart, should I clean it or something? What should I use?
#1318
Clean the inside of the manifold with a lot of carb cleaner and clean the passages well. Also degrease the top of the motor to clean it while its off
#1319
How about the cavities (openings) where the fuel injecters/lifters are? Or should I do the seafoam stuff after all is reconnected?
#1320
Dont dump anything in those. Wait till everythings back on and then sea foam it.
