Old 07-04-2012, 02:38 PM
I started mine up and drove it around the block the other day after 3 months of just sitting.
http://youtu.be/i7x4wFMZBpo
Before that I replaced the battery, terminals, steering rack, and lower L control arm.
Still have yet to check dealer prices on a fender for comparison. I just can't seem to remember. It's the only thing I need aside from body work and paint.
Old 07-04-2012, 04:19 PM
Subix's Avatar
Subix Subix is offline
My Other car is a GENIUS Car!
The terminals look great. Where did you pick those up from?
1994 subaru svx le 112k
Old 07-05-2012, 04:35 PM
I have been looking for years and Ebay is the best place. Local places stopped stocking things like this due to lack of market demand.
these terminals are larger than I thought so my jumper cables don't fit. I had to just hold the teeth to it to jump my FEZ, so beware.
Old 07-06-2012, 09:10 PM
dannmarr's Avatar
dannmarr dannmarr is offline
I work for my SVX
She's ALIVE! She's ALIVE! I replaced the bad coil and my babe is back! Now this is the car I remember driving!
Subaru SVX for fun
Susuki SX4 for my older son
Ford Ranger for work
Old 07-07-2012, 04:54 PM
david_12121's Avatar
david_12121 david_12121 is offline
The NEWBIE
put the new speakers in...sounds awesome
close to 1000w of awesomeness, without a subwoofer!
also fixed the window rattling when it's down
DIY FTW!
1993 SVX 25th Anniversary Edition @+142k
-Rebuilt Tranny @135k
-Regasketed Engine @140k
-Enkei Raijin 18x8.5, with 255/35/18's @140k
-BC racing Coilovers (From STI's) @142k
Old 07-07-2012, 05:53 PM
Rod.'s Avatar
Rod. Rod. is offline
Thumbs up Re: What have you done to your SVX (or other Subaru) today?
Brought my '92 home on the hook after it donated its drive shaft anf transfer case to my '97, which is having the transfer case rebuilt and new front brake calipers. It's been 2 months but I should be driving again next week.
And it'll have a Bontrager RSB!
Rod.
'97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD
'92 Ebony LS-L #6851, USDM (sold)
'08 Forester (wife's)
'06 STi (traded for the Forester)
'94 Legacy wagon (sold)
Old 07-08-2012, 09:02 PM
dannmarr's Avatar
I work for my SVX
I installed the quick shift kit and DAMN! With a new coil, new spark plugs and power mode, I think I'm about to cry Thanks Harvey!
Subaru SVX for fun
Old 07-08-2012, 09:08 PM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
*Ricer mode engaged*
I chopped off (Well, nate did) my midpipe because I was aggravated with the resonator buzz.
Old 07-10-2012, 07:14 AM
processengr's Avatar
Replaced OEM rotors and brakes in 97 with silver zinc plated rotors and Bendix thermoquiet pads from Advance auto, painted calipers, flushed brake fluid with ATE Blue. Painted the removed rotors, put into the 92 Ebony, painted calipers, purged brake fluid again with the blue ATE. Changed rear diff fluid with M1 75/90. Ordered Derale ATF thermostat for front mounted cooler.
Bypassed radiator cooler on silver 92, installing temp gauge...cooler on silver is mounted in fender wing, with SPA fan thermostat controlled, filter also in wing...purging the ATE blue with Valvoline DOT4
Cheers! Gordon
1992 Ebony 251k 444 SOLD
1999 Silver SLK230 134k SOLD
1997 Green Outback 137k SOLD
2013 Honda Accord I4 SOLD
2015 Subaru Crosstrek 30k
2018 Tesla M3 30k
Old 07-10-2012, 08:56 AM
So, the Black now has silver and blue, and the Silver has gold?!
I am sooo confused!
Old 07-10-2012, 11:07 AM
Smile Re: What have you done to your SVX (or other Subaru) today?
The blacks have blue, and the Silver now has gold
Cheers! Gordon
2018 Tesla M3 30k
Old 07-10-2012, 01:08 PM
My head hurts.
Old 07-10-2012, 01:54 PM
jellybytes2 jellybytes2 is offline
soup IS good food
Picked up the SVX from paint shop. Had the roof and spoiler redone. I'll post better pics later. Now its off to the mechanic to replace the leaking PS return pipe and do something about the rusted out exhaust connections.
'97 SVX 'Brilliant' Reddish
'94 SVX Lagina
'93 SVX Less Reddish
'89 XT6
'08 Impreza
'18 Crosstrek
Totaled
'98 LGT ~180K
'97 OBW ~185k
Sold
'89 XT6
'04 VDC Sedan
Parts
'89 XT6
'96 SVX
Old 07-12-2012, 04:06 PM
Rod.'s Avatar
Drove my '97 home today.
I'd brought it in on May 1 to have a slow leak in a tire looked after.
Ten weeks and several dollars later, its had the transfer case rebuilt (with the housing from the '92), a new awd solenoid and clutch pack, the drive shaft replaced with the one from the '92, a front brake caliper replaced and rotor machined, recharged the a/c, and fixed the slow leak.
While they were at it, they installed the rear sway bar I got from Nevin.
Should be good to go!!
Rod.
Old 07-13-2012, 02:03 PM
Monday, on the way home, the rubber clutch line suddenly started leaking. Like, pedal really soft and if you hold it in too long, pressure is lost and you have to let it out and push it back in. Drove 10 miles, almost without using the clutch at all. 6-speed didn't enjoy it (only ground a wee bit), but I made it home. Helped that there was no traffic because it was at like 2 AM. Checked the line out when I got home; I think it's the one that was originally with the 6-speed, which is an 02 JDM one. So, 10 years, sounds like time for the line to die. Ordered a stainless WRX line on ebay, got here yesterday, replaced it last night, bled the clutch, good to go.
The stainless line feels a lot better than the rubber one. Much more control over the clutch now, and takes less pedal movement to get the same amount of clutch release. I was a wee bit nervous about the proximity to the + line on the starter, and it being conductive now instead of rubber, so I bent the metal line a bit to get it a bit farther away. Works great, but it makes an ugly mess of line in there now. Next time the car's all taken apart, I'll see if I can have a nicer looking full stainless steel line made instead.
Now I'm waiting for the next thing to go wrong...
