#106
Re: hmmm interesting ... custom made coilovers
I need struts, this has me interested, I got a few questions.
So one set of them has rubber top mount and the other set has metal? Are they are both the adjustable type top mounts? What is the difference between these 2 sets in ride and performance and cost? This is a direct bolt on replacement? |
#107
Ok ran into a problem trying to install these, I seen my top plate looks different then the other photos I believe it is the wrong one, the bolt holes dont match up.
#108
And another problem, the rear top plate is the right size but the opening to the knuckle(front and rear I checked) is too small. The knuckle has a 30mm thickness and the coilovers are only 26mm.
#109
Hmmm, not so bolt in after all. What's your course of action going to be; to modify until they fit or request replacement parts?
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#110
How do the two bolts of the lower flange match the knuckles? It looks like the WRX fitment of my Stance coilovers.
#111
I am just going to take the wait and see approach, I dont know how much these cost in relation to other setups but I feel I paid enough to have parts that work. I could grind down the knuckles if I needed but that is a last resort. the bolt hole placement looks to be good. one hole is slightly slotted, for more adjustment I guess. |
#112
Doesn't look like it's in the right location, does it? Based on my experience with my "non-stock" front sway bar and the way the stock brackets are attached to the strut housing, I'd have to say the brackets shown in the pic will be bent out of shape in no time... Bill
#113
The lower mounts on mine are definitely wrong like yours are. I almost immediately noticed that they looked too narrow, but I kind of ignored it. I haven't checked the top mounts. I recall that the guy who got the very first set of these coilovers several months ago had issues with fitment, and cedric did make it right for him.
2009 Volvo C70 T5 2008 Volvo S80 V8 2006 Range Rover Sport 2001 Audi S8 |
#114
the pics posted it looks bigger then the one I have. I think mine was a mistake in packing I remember the guy in au I think he shaved off the knuckle |
#115
#116
My top plates do seem to be correct. They are black. I got an email back from cedric and he said that he will send replacement parts for the lower knuckle mounts.
#117
Thanks! Brian |
#118
and a well used, Konified SVX front STRUT, and they were 30.04mm rear, and 30.98mm front. I do not at this minute have an SVX on the lift, but will tomorrow, and can check the ACTUAL knuckles.
#119
Thank you sir - mine is currently getting a clutch and a much fresher motor put into it
#120
I checked with a rough caliper gauge I have and it looked like the front and rear actual knuckle was 30, I wonder if making the mount for the coil over 31 would hurt. I know the strut mounts are 31.5-32 but they are made to compress.
