Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
  #91
Old 04-30-2013, 01:47 PM
Re: Ice's fully-baked turbo build
Never lift: You think that is a stock set up? Never saw a stock auto with this all sticking out!
Old 04-30-2013, 02:50 PM
neverLift neverLift is offline
Haha no no, not that intercooler in particular. Factory was two small side mount intercoolers, no? I was just referring to it being twin-turbo from the factory.
Old 04-30-2013, 04:09 PM
Well the front bumper isn't on in that picture...
Old 05-01-2013, 01:26 PM
BRZCory BRZCory is offline
I also have a secret project I'm working on that would render the power steering lines unnecessary.
Something something MR2...
Old 05-01-2013, 01:54 PM
Something something trunk mounted...
Also something something double speed sensitive...
Old 05-01-2013, 05:57 PM
Tireiron Tireiron is offline
I wouldn't mind figuring out how to get the electric rack from the BRZ and other newest gen subies into the SVX to get rid of all that fluid and plumbing. Then it would also allow me to get my alternator back on top of the motor in place of the PS pump and not so scarily close to the ground.
Old 05-01-2013, 06:35 PM
The mounting of the BRZ rack is very different from the SVX and would require modification of the subframe to fit. That being said, if you could make it work it would be an awesome mod. Not only to remove the pump and associated parts/weight, but also to get a better steering ratio. I don't know what the SVX has (Google isn't helping me out much), but a BRZ's rack is 13.1:1. Compare this to a WRX at 16.5 and STi at 15:1. I have a feeling it would take significant rework of the bits under the dashboard though, the electric motor on the column probably occupies a fair amount of space that's currently used by other things.
Old 05-03-2013, 02:00 AM
NeedForSpeed NeedForSpeed is offline
Chris,
The SVX rack ratio is 16.2:1.
The RHD JDM 4WS front rack is 14.2:1
Special Thanks to Our Friends and Sponsors:
http://www.alcyone.org.uk/ssm http://www.PhenixWheels.com http://www.dba.com.au/
http://www.ClassicSoftTrim.com http://ToyoTires.com/tire/pattern/versado-lx Gillman Subaru of Houston
"QuickChange" http://www.TransGo.com/ http://www.PlanetSVX.com Bontrager Works,
'92 Subaru SVX LS-L Claret ORIGINAL OWNER
'92 LS-L Pearl~ '92 LS Pearl~ '92 LS-L Teal~ '92 LS-L Silver~ '95 LSi Polo~
'92 JDM Alcyone SVX Version-L 4WS Pearl~ http://www.subaru-svx.net/forum/showthread.php?t=54143
'92 JDM Alcyone SVX Version-L 4WS Ebony~ http://www.subaru-svx.net/forum/showthread.php?t=54117
Old 05-03-2013, 06:09 AM
Well how about that. I wonder if the rack and pinion gears from a RHD rack could be swapped into a LHD one, it would be a huge improvement.
Actually now that I'm drawing it in my head I don't think it would work. The spiral/helix on the pinion is probably reversed due to the angle the steering couple meets the rack at. Darn.
Old 05-03-2013, 02:59 PM
bazza bazza is offline
To be honest I think the stock rack is quite nice. If anything you want to decrease the turning circle. My foz has a turning circle about half the svx - would love to do that to svx. I've raced with the 3.7 turn Rs rack, 2.7 wrx / sti and a mate has the 2.2 turn rack - I don't really ever notice a difference. I think if it was for drift or rally then I might, but for hills or track work no.
Old 08-10-2013, 10:04 AM
BackWoodsBob BackWoodsBob is offline
No updates because I'm doing work on a house I bought, so once I'm moved in I can hit my car projects hard and get stuff done quickly, since I'll have a nice, comfy garage to work in instead of my parents' driveway.
I am actually back to thinking twin turbo is the way to go. Piping may actually be much easier than I thought. Two WRX TD04s ought to do the job pretty well I think.
I didn't look at compressor maps for the TD04 or the HX35x yet (kinda busy tonight), but if you're looking at compressor maps, the pressure ratio and airflow rate I'm looking for are ~1.7 and ~587 cfm. (Half the airflow rate for twin turbos, but leave the pressure ratio the same).
A quick Google of "HX35x compressor map" leads me to believe that it would be way too big for my setup.
after lots of reading and careful compressor map study i?vs decided to go twin tdo4s. they're cheap and relatively plentiful. Im looking for a PR:1,4-1,7 and about 500cfm.
