Old 04-15-2012, 05:22 PM
Re: $36 Replacement ignition coils?
I am really wishing I had paid more attention in the electrical part of physics class.
What I have gathered from talking with Matt is that you can just put 6 ignitor thingies inside the Megasquirt itself. Also, the LS2 coils have ignitors built in that match them, so using those particular coils with the Megasquirt might be a good idea, just for simplicity's sake.
SMC, I have the megasquirt stuff about 75% figured out. Would you be interested in trying it too? You are going to be needing some kind of engine management anyway.
Old 04-15-2012, 05:31 PM
smc smc is offline
I was looking in depth into the hydra systems, as I plan on running a few different stages of ignition. The latest version of Hydra has provisions in the programming for launch control and a few different levels of antilag.
Currently, Im looking as MSD coils with a 0.680 ohm and 0.700 ohm primary resistance. Hmm.
Old 04-15-2012, 05:40 PM
MS3 can do launch control: http://www.msextra.com/doc/ms3/launch.html
I was thinking to get a hydra, but an MS3 would be around $1k cheaper. Means more money to go to hardware. But the hydra would definitely be easier.
You mean MSD ignition?
Old 04-15-2012, 08:24 PM
smc smc is offline
http://www.summitracing.com/parts/MSD-8226/
Wow. MS has come a long way over the years! Ill start doing some digging on it.
Old 07-30-2012, 08:42 PM
ShiuludeSVX's Avatar
Bump... Any new information about these items?
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 07-30-2012, 08:51 PM
smc smc is offline
With the stock ecu, the new coils are working like a champ. Zero issues as of yet. Ive put over 6,000 miles on them. And most of that was 'spirited' driving including a few autocross events and one open track day with the scca. Fine from idle to the rev limiter.
Old 07-31-2012, 09:55 PM
Thanks for the update. I needed to make sure of this before making the change
The Worm
_______________
No Mods, 33K Miles
Old 09-26-2012, 11:12 PM
BackWoodsBob BackWoodsBob is offline
So Mr. Harvey, what would be the risk of running these coils long-term on the stock ecu with no modifications to the timing at all?
Old 10-15-2012, 08:46 PM
Plug Wires for this setup
Tried to fit several things to the inlets, but came up with this.
The wire set can be shortened, if you like, and if you have the detail talent.
As they are, there is no greater difficulty, then re-inserting the original "Coil on Plug" configuration.
Can someone explain how to inline the pictures, instead of attaching.
Thanks
The Worm
_______________
No Mods, 33K Miles
Old 10-15-2012, 09:05 PM
Re: Plug Wires for this setup
You need to first host them somewhere (The photo post function here, photobucket, facebook, etc), copy the URL of the picture (in Internet Explorer right click on the image and go to properties), and then paste that URL into your post here with [IMG] in front and [/IMG] at the end.
Example: [IMG]picture.address[/IMG]
Old 10-15-2012, 10:14 PM
It works well with pics uploaded to this site, if you copy the link URLs after you have uploaded them using the "manage attachments" menu and put them between [img] tags.
Old 10-15-2012, 10:57 PM
Thanks for the help. I jumped in and did all 6 coils and it has cleared up my rough engine. So, for the full price of 1 new Coil on Plug, I got a full set of this option. Yahhhh
The Worm
_______________
No Mods, 33K Miles
Old 10-18-2012, 10:38 AM
92 SVX 92 SVX is offline
considering how far down that spark plug is how difficult was it to connect a normal spark plug wire to the plug?
Old 10-18-2012, 02:47 PM
The set that I got worked perfectly. Things got a bit tight at the #6 plug, but it is no harder than the regular coil on plug routine.
Trying to get a regular wire on it is pretty hard, being that it's hard to feel the "click" when it's locked in place, and chasing that far in, to get ON the plug.
The Worm
_______________
No Mods, 33K Miles
Old 11-06-2012, 01:53 AM
bishop bishop is offline
Any updates on this? I think my car may be having rough idle because of a weak coil and im doing everything i can before putting money in to a new replacement coil.
