Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
  #46
Old 09-16-2012, 12:09 AM
Re: Ice's fully-baked turbo build
After masking and painting:
Old 09-16-2012, 12:31 PM
pearlm30's Avatar
pearlm30 pearlm30 is offline
cant wait to hear it running!!! Great job!!!
94 Bordeaux Pearl SVX Lsi B&M cooler with Aux ATF filter. QC Kit Plus 06 Sti Gold Wheels. SOLD
92 Claret WRX 5 speed ECUTune 1AV1 Gold STI Wheels & more. SOLD
92 Teal SVX LSL lowered with Konig. SOLD
92 Black SVX LSL with B&M cooler & Aux filter. Small Car Shift Kit. Gone
94 Red SVX L FWDwith LSL Leather Interior. SOLD
92 Teal SVX LSL....with B&M cooler & Aux filter. Small Car Shift Kit. SOLD
95 Polo Green........With Trany Problem. GONE
Almost complete Rear Wheel Bearings Job with Pictures in my locker
My Locker http://www.subaru-svx.net/photos/user.php?pearlm30
Old 09-16-2012, 12:38 PM
Old 09-16-2012, 12:47 PM
Ok so the overall plan is basically this:
step 1: get parts to build engine - done
step 2: have engine build - done
step 3: put engine together the rest of the way
step 4: make current engine run on the megasquirt
step 5: swap new engine into car, run on the megasquirt
step 6: buy turbo, intercooler, etc
step 7: have turbo piping made and put it all together
step 8: lots of tuning
So still a very long way from being done, but some significant progress nonetheless. The rest of the engine, is in storage until we buy a house, so I can't really do any assembly for a while. I might go ahead and order a megasquirt and get started figuring that out in the meantime.
Old 09-17-2012, 09:47 AM
neverLift neverLift is offline
I can't tell from the photos, are ARP head studs in all positions? Or just the center ones (i.e. using (2) sets of EJ2X studs)?
cheers
-Evan
Old 09-17-2012, 10:09 AM
cheers
-Evan
All positions. You can get them from atomicspeedware.com, which is run by Nick Arias. The site is down for a redesign at the moment, but their facebook page is here: https://www.facebook.com/atomic.speedware and there is a contact number. (Actually if you scroll down the page a bit there are some pictures of a custom stroker crank that they made for the EG33. Very cool.)
There are 8 headbolts per side, 4 longer, and 4 shorter. The longer ones go in the center spots, and the shorter ones go in the front and back pairs of spots. When I ordered them I got 16 long ones, and had to send back 8, and then they sent the right ones. So they should have the right ARP part numbers on hand now to make the sets correctly, but you will still want to double check.
Old 09-17-2012, 07:34 PM
Brilliant, thanks!
I appreciate you taking the time to answer all of my questions. The engine is looking good!
cheers
-Evan
Old 09-17-2012, 08:02 PM
bazza bazza is offline
Out of interest, what was the pricing for the full headstud kit? Interesting you went the full kit rather than just pinning the center piston. I've gone the other way, ditching my 6 year old ARPs, for the new AGE ARP's but in centre location only. Been told it will handle 28 psi hahaha... I'll be happy with 14 odd.
Old 09-19-2012, 08:15 AM
Brilliant, thanks!
No problem man. And thanks.
It was $300-something. Honestly, part of the reason I went ahead and got them was that people have had trouble getting proper EG33 sets in the past, so I figured I might not be able to get them in the future if I didn't get them now.
Old 10-10-2012, 07:37 PM
Weirdest thing just happened and I wanted to share. The guy who fixed the 6-speed before I put it into my blue car (it had no reverse due to a broken shift fork) just discovered facebook, and I happened across some pictures that he took of 6-speed when it was all taken apart:
Old 10-10-2012, 07:41 PM
Nice!!! I've had to rebuild mine twice due to breaking the same part, the funny thing is the reverse and 1-6 selectors are the same part number and they're half the size of the 5MT part. Which is annoying because the 6MT is near bullet proof except for this one part. The good thing is it's only $45 from Subaru - the bad thing is the entire box needs to be stripped down and I've found there is a certain torx bit which lasts about 1 install due to the torque setting Subaru require.
However PPG from Adelaide can supply you with a billet selector which is far stronger.
Old 10-10-2012, 08:16 PM
Old 10-10-2012, 09:10 PM
^ Yea that was a surprise. These are getting a surprising amount of attention from non-SVX people...
Very cool. Yea I was tempted to try and fix it myself, but decided it was too risky, what with my having had no idea what I'd be getting myself into. If I ever have it apart I'll check those out.
Old 11-04-2012, 01:17 PM
(Posted in the "What have you done to your SVX today?" thread, but also wanted to cross-post it here for posterity.)
Stayed up until [7]AM last night going through wiring diagrams, pinouts, and the actual wires of my spare engine and body harnesses getting the megasquirt wiring figured out. Pleased to say that I have it about 95% figured out. All that's left to figure out is:
1: whether the crank and cam sensors need any resistors to get a good enough signal to the megasquirt, and there's no real way to make sure of that without actual experimentation.
and 2: how to wire up the IRIS solenoid, which I will probably leave until later because it's not needed to just get the car running. The stock ECU has a constant, switched +12V going to one pin on the solenoid, and grounds the other at the ECU to switch it on (closes the IRIS valve) above 2200 and below 4000 RPMs. The megasquirt has many spare outputs that I can use for this, but I am slightly confused about whether some of them provide ground or power (and if so, whether they are +12V or +5V), and a lot of them are PWM, which I'm not sure whether it would be appropriate to use to drive the solenoid. Probably need to post up on the MS forums for an answer to that one.
I will start actually wiring it up tonight, and post my wiring diagrams and such very clearly and with plenty of explanation soon, once I have verified that it (at least mostly) makes real-world sense.
Very satisfied and proud of myself.
Old 11-04-2012, 02:54 PM
Stevebsy's Avatar
Stevebsy Stevebsy is offline
Administrator
Very interested in seeing how the MS build goes!
I built one that I put on an XT/4 turbo a long time ago. Made a huge difference compared to the antique ECM it had. Good to see that it can now be used with the Subaru crank/cam sensors on the new versions of the MS.
'20 Honda Ridgeline
http://www.x35design.com
