#541
Installed a legitimate FPR regulator (Aeromotive 13105) and gauge to replace the stocker that crapped out on me.
I'm glad that I read around here somewhere that stock pressure is an industry atypical 36psi!
Disclaimer: The above post is on the internet. |
#542
mine shows about 34 psi
#543
Two psi off the mark ain't bad.
#544
What would be typical?
#545
I've seen a lot of specs listed at 43.5psi (3 bar).
#546
I washed it
1995 POLO LSI 76K MILES SOLD |
#547
Today in the rain??//
#548
I knew you say that, no last night, and then stuck it in the garage
#549
Took the radiator out and had it cleaned there was so much filth inside that it was impeding the flow, Now I dont get any rise in the temps I am much happier.
#550
Took the car to SVXFiles garage where he fixed my ATF leak, replaced my front sway bar bushings, adjusted my shifter and hooked me up with a very nice Sunroof Wind Deflector. Thanks man!
1992 LSL ebony pearl 170k - Thank you Ron Mummert Reading Box of Wine Car ----------------------------------- 1992 SVX LSL 5-Speed Sold at 180K 2019 1995 SVX Lsi Polo Sold at 118K 2007 |
#551
I appreciate this. So does my mortgage company, insurance agent, parts store, electric company, bartender, WAIT, I am my bartender!!!
#552
Brought her in to the shop to have a sticking rear disk brake looked at. Getting both disks r/r and new pads, too. Should be ready tomorrow...
Rod. '97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD '92 Ebony LS-L #6851, USDM (sold) '08 Forester (wife's) '06 STi (traded for the Forester) '94 Legacy wagon (sold) |
#553
And I replaced the left-rear side marker lens with one I found on eBay. It's got a similar cracking as my original one around the light socket hole, but not as bad. My '92 is cracked in the same way so I'm thinking it's a common flaw.
Rod. '97 Ebony LSi #426, CDM (1 of 51 in '97), 185k km, rebuilt engine & transfer case; 22mm Bontrager RSB; 4300k HID 9006 bulbs SOLD '92 Ebony LS-L #6851, USDM (sold) '08 Forester (wife's) '06 STi (traded for the Forester) '94 Legacy wagon (sold) Last edited by Rod.; 10-21-2011 at 08:48 PM. |
#554
replaced that pesky p/s o-ring.
I can parallel park and make u-turns again! :b anana: also found a small stream of white smoke coming from oil fill tube :/ |
#555
Won my first Trophy "BEST Classic Import "
