#526
Re: Building a 10,000 rpm NA engine.
This is the best I can do to show what it looks like, Harvey.
#527
One point from the past that I want to mention was I asked the question,
"On a turbo engine what is the final compression ratio based on a given boast" Now many years later I think there is a answer, If the turbo engine is at 15lb boast approx then from before we know that the engine has approx double the quanity of air. It would assume that if the normal NA engine has 10:1 compression ratio and you turbo to 15lb or double its volume the compression in terms of head load is the same as 20:1 NA engine. Does anyone agree. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#528
#529
and as icing says the boost depends on RPM more than a supercharged engine would.
#530
I almost agree, if you talk 'compression pressure' changing, and not the 'compression ratio' that, does not change.
#531
So Harvey I want to go to 14:1 compression by shaving the heads. How much should we take off? Also does you simulator show much difference in power from 10:1 to 14:1 at say 8,000rpm. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 12-13-2012 at 08:54 PM. |
#532
I'll raise the ratio on the present one to 14:1 to see, tonight. Harvey.
#533
Also I would not worry about the compression ratio yet, till we get the cam timing and lift finalizes, as we have to fit the valve heads on overlap into the chamber on TDC.
#534
Tony
#535
Game enough to put a percentage on it?
Tom and Ice want to have a go at what % increase from 10:1 to 14:1? Harvey.
#536
Okay so the % is based on Simulator or actual?
#537
It will be the same simulation that I posted, with just the com ratio changed from 10:1 to 14:1
#538
So base case was 10:1,
My guess is 14%
#539
My best guess is less than 10%.
For example; Bowling's Compression Ratio -> HP CalculatorComputation Results: Engine Horsepower (peak) is 230 Old Compression Ratio is 10.0 New Compression Ratio is 14.0 Computation Results: Computed New Engine HP is 249, a 8 percent change
#540
From Wallace Racing;
Your old Compression Ratio of 10 and HP of 230 is now calculated as a Compression Ratio of 14 and 249.16 Horsepower.
