#481
Re: Building a 10,000 rpm NA engine.
36.3 PSI with the stock regulator. I believe about 80%. 14.7 PSI, or 1 bar.
#482
#483
In the stanadard type dry sump you need to have a tank to get rid of the air, so the low pressure suction from engine sump would go to the tank. From Tank to inlet of high pressure pump then out of pump and into the oil line on the block which could be were the oil filter is.
I may have miss understood you question if so yell. Thanks Tom much appricated. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#484
Is the tank to get rid of the air separate from the reservoir tank?
I was thinking to retain the stock oil pump to supply the block, and just use the 1-stage pump to pump oil from the pan to a reservoir tank, which then would supply the stock oil pump. So there will be 2 pumps total.
#485
Correct. You may have issues getting the oil from the sump to the other tank and back to stock pump.
#486
So it ought to be pumped to the stock pump?
#487
Tony, I'm still running stock regulator with the turbo setup - I assume the pressure is raising with boost.
As for injectors, the 80% is a figure used by tuners to sell you a bigger set of injectors but in reality you run up to 100% and when you see the AFR's not responding you know you've maxed them out and the power figure or boost or whatever to keep well under. |
#488
Tony
#489
The fuel doesn't actually sit on the valve, it's a mist, never liquid unless cold starting - hence why you need twice as much fuel when cold as much of it doesn't vaporise and at race rpm, say 3500rpm+ the mist is there for about 5-10 ms. It's actually beneficial as it helps cool the inlet valves on the way in - batch fire is also nice to ensure nicer cooling on the way into the engine. Batch fire is when all 6 injectors fire at once. As for the 40% duty, that means the injector is open for about 288 degrees - which means if you want the valve open the entire time - you need inlet cams with that duration. Standard SVX cam is about 236 degrees, means you'll need to run max of 33% duty if you want the injector open only when the inlet cam has the valve open. However it doesn't work like that in reality... they usually finish injection 300-400 degrees BTDC, about 300 degrees before the cam is even thinking about opening. |
#490
Or when groups of 2 or 3 are fired together.
M |
#491
Or you can fire them two or three times per 720 degrees. Didn't want to go into to much detail to confuse people lol
#492
It is a known fact that if you got perfect airfuel mixing you will get maxium burn and therefore maxium power is all other factors are equal. The idea that you are getting sequencial injection when the duty get close to 100% is crazy. What we know as facts are:- Sequencial injection is better then group or batch firing. The better the fuel air mix the better the burn. Air velocities in the intake manifold change based on when the valve is open. The way I see it we want to take those knowns and build on them.
#493
Hi Tony!
How goes the engine dyno? Cheers Bill
#494
You'd really need to investigate a new head design (like the BRZ) and direct port injection and thermal coatings to make this work. Quote:
#495
Bazza I don't agree at all,
You are totally missing my point but thats the way life is. Hi Bill, Okay part arrived for the gearbox now it just a matter of finding time to do the welding mods to be able to fit the gearbox and tail shaft. I think there is a couple of days work to fire it up so hopfully I can find the time in the next couple of weeks. Pretty exciting really. Have to put the mid engine on hold till I get the dyno running. Tony
