#466
Re: Building a 10,000 rpm NA engine.
Oh Tony you shouldn't do this.
Do you realise how much time and money these blokes put into their rigs, to be able to drive across the desert, and climb these sand dunes? You have just crushed their whole lives work. Harvey.
#467
Harvey,
We were traveling with 2 other 4 wheel drives and everyone was to agree on the, "Quote of the Day" When we climbed the dune there were about 40 people around and were the rest of our group were at the base of the dune the quote of the day was heard said, it was, "F_ _ K the 4 wheel drive what we need is a Subaru Sports car". Its pretty funny. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#468
In light of all the discussion about what to do to develop more power we need to advance this a bit. Something Bazza said is going around in my head and also Harvey made the simlar point but in a different context.
Bazza mentioned that on one of the Subaru engine they reduced the size/dia of the intake ports in later models of the same engine. This was done for better torque and I am guess better cyclinder fill. Harvey made the point on a number of occusions that have the ports intake and exhaust just big may reduce power and that there is a need to have some exhaust pipe on the manifold to enable the gases to pull the last little bit out of the cyclinder. Okay so were am I heading, We seem to ASSUME that we need to port our heads to get more airflow, We assume we need more lift on the valves, If the ECU if changed we will see a massive power increase, When in fact we have no idea if there is any gain to be had, Harvey keeps making the point that the engine are very effecent and have high fill ratio, so is all this changes we are going to make going to gain anything or infact reduce the power. Maybe what we need to do to get more power is to just change the cams and thats it unless you won't to increase revs like I do. Clearly we need to set up the engine dyno and put a stock standard engine with a standard ECU to get some base line numbers and then change out some parts. Matt has been knid enough to offer to loan me the throttle bodies so we can check that out as well. So whats every one thing. Tony
#469
Please read to the end. I have a 1750 CFM axial vane supercharger bolted to an otherwise almost stock SVX 3.3. With some very minor porting, (pictures in my old locker) stock cams, and a free flowinng exhaust system including equal length headers, I was seeing up to 11PSI. I lent my supercharger to a friend with a 5.2 L, 2002 Suburban with stock cam, heads, headers and free flowing exhaust. His stock crankshaft pulley was bigger in diameter than my 6.5 inch custom made one. He saw 15 PSI! His bigger engine should have made less PSI as it is a bigger room to fill. His crankshaft pulley was bigger to spin my supercharger faster, pumping more air. My conclusion, our stock engines can flow a hell of a lot of air!
#470
I would say these engines need both cams (basic regrind) and exhaust headers (like Jack's) to get them revving cleanly to 7000 rpm and pulling all the way there. Currently as I've said and experienced in your Desert Monster and my own setup is they tend to fall over around 5600 rpm with the stock cam and the torque and power drops off above that. |
#471
Its a interesting point you make. We have to get the engine dyno going ASAP to put some meat around all this stuff. Tony
#472
Tony/Harvey,
It would be great to have Harvey's EG33 computer model "tweaked" based on actual engine dyno results. Example -- increase intake runners by 3 inches in length. Model predicts X, actual dyno results show Y. Go back and tweak model so that it predicts Y. Just a thought for the path forward. Bill
#473
Yes Bill you are right,
Unless we start somewhere we are never going to know. As I see it the engine that I got from Mike has cam specs that I am sure Harvey has and the compression is known as well so based on that we should be able to drop it in the dyno and see what is does. THen compare to Harvey's simulator. So now the ball is in my court to get the dyno running. Tony
#474
Bravo! Here's to dyno runs and correlation to computer models! Bill
#476
I work with NASA scientists whose careers have been wrapped around modeling the various aspects of the Earth and one of the things I've learned is that every computer model/simulation has its own "quirks" and that they all benefit tremendously from the input of real data ("Cal/Val"), be it from ground/air/space-based assets. I look forward to seeing how your simulations and Harvey's match up with/benefit from the input of dyno and drag passes! Things are starting to get interesting, aren't they! Thanks for all your hard work and efforts. I've found myself wondering how much it would cost to fly down to Australia and take an extended "SVX racing" holiday Bill
#477
Hi Bill,
I have a big house no kids plenty of spare rooms so you are welcome any time to come and stay. Plenty SVX things to bury your head in. You got me thinking so I will move this to a new thread. Tony
#478
How beneficial would it be to run a pump like this pulling through a pickup in the stock oil pan, to a reservoir feeding the stock oil pump?
Kind of like this: http://www.subaru-svx.net/forum/showthread.php?t=60915 I could cut off the end of a stock oil pickup where it connects to the pump, and have it welded through the side of the oil pan, and put fittings on the cut end somehow, and have another line that returns oil back to the stock pump. Like this picture: What do you guys think? Stupid idea trying to cheap-out on a dry sump?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ............Photo album Last edited by icingdeath88; 11-30-2012 at 08:51 PM. |
#479
Changing to that pump won't give much benfit and will creat to many headaches. The concept is good but,
To get around the cavitation problem you need to have a seperate oil tank and to do that you have to have a minium of 2 stage pumps, one suction one pressure. The other issue is there is not much room between the front of the block and the timing belt to get the suction past everything. For the mid engine car I am building I have lowered the engine and gearbox by about 100mm and also aim to lower car by about 50mm. My aim being to drop the CG of the car lower. Okay Bazza and I have been having a debate about the dry sump. I personally think that we should use a 2 or 3 stage pump and forget about pumping oil back from the heads. One of the stages needs to be pressure. In the mid engine thread I will post a image of the engine block sitting in the subframe with the new engine mounts etc and you can see how low it is, not sure were I will discuss the simpler dry sump set up but will explain it in the near future. Tony
#480
My question,
I am flat as a lizard drinking and don't have time to look so can anyone tell me the following, Size of standard injectors? Fuel pressure in PSI? If possiable maxium duty cycle of our injectors? Other updates, - Rear drive lock for 5 speed transmission for dyno arrived so I have to get on that soon so we can run some tests. - My mind is thinking and I wonder how much pain a standard SVX engine can take, in other words can the standard valves, pistons & rod run a lot higher revs that we have all assumed possiable before. I need to find out so it maybe time to distroy a engine. - Anybody know how many stage pump in a porsche engine and if some one has a oil flow diagram it would be very help full. Any ideas on engine loads for a turbo engine, in other words its a 3.3l engine what boast number do I need to get to acheive a 6.6l equlivant. If this sounds stupid, go with me for the minute. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 12-01-2012 at 12:44 AM. |
