#31
tunnel ram effect? NAh, that stuff is for like..tornados and stuff. just a safe barrier to reduce heat transfer via conduction. I remember my old engine with the spacers, after a long drive, I could easilly hold my hand on the intake manifold, whereas I have a hard time doing so without them
....Mabey Ill do a little thermometer based expeiment when I re-install them
R.I.P Cool Signature. You're gone but not forgotten. I mean, sure, I kindof don't remember some of the finer details..but I remember you were funny, and at one point you said spaghetti in Dutch....but definantly not forgotten |
#32
i think that the claim is 6%-10% at the crank. I dont know how much of an effect they have on the svx in terms of hp, but as eric said after spirited driving you can hold your hand on the manifold.
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
#33
This may mean nothing, or it may mean a lot of things, but after a while I felt as if these spacers lost effectiveness somewhere to the tune of 15 degrees. When freshly installed, the mani was always never hot. Recently it would become... somewhat hot, slightly warmer than warm. May just be my imagination.
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
#34
"tunnel ram effect? NAh, that stuff is for like..tornados and stuff."
Um, what? Tornado "and stuff"? So you are talking about the fuel saver thing? ![]() OK, not to mock, but, really? Not to say that F1 is the tip top, but increased air velocity is the key to making power in the top end on a n/a motor. The eg33 is operating at half the revs so I was just wandering if the lower revs and no venturi effect has any part to play on our simple n/a motors. I'm not trying to be abrasive, just curious.
"They that can give up essential liberty to obtain a little temporary safety deserve neither liberty nor safety." Benjamin Franklin blk 92' LSL w/ average mods pics here http://s306.photobucket.com/albums/nn277/yourconfused/ Cash68: "Hmm, I wouldn't brag about beating Escorts. That's like saying you tricked a retarded person." |
#35
#36
Half the revs of an F1.
#37
I was thinking they did like 12k to 14k. That data is several years old. Has it changed?
#38
19,000, which is a regulation limit.
NA engine builds may soon yeild 8k rev ranges, so you are not necessarily off on your statement.
#39
What???
Before I installed the Outlaw spacers my intake manifold was 200F. Just like the top of the engine block. Now its 140F. ![]() Granted I had it ceramic coated while it was off, but the spacers do help in stopping heat transfer. Buy em, install em, and be happy! ![]()
#40
Re: PHENOLIC SPACERS......by Outlaw Engineering
sorry to bring back an old topic but I just want to know if I have to use the oem torq spec or they have a specific one?
#41
My recolection is.. the same Torque.. ? BUT, I had major problems with their spacers that had gaskets attached (with "goo") .. They slid sideways twice ..
Jim 1995 Laguna Blue SVX AWD L - 240K (daily driver) - "ReBuILT" used engine at 236K miles (6/13) 2013 Veloster Red - Driver Now??Dropsprings [1/2" rear, 1" front] with Koni Strut Inserts> Magnaflow Exhaust System> ECUTune Stage 1av1 Upgrade (from 1v4)> ECUTune TCU MOD> Aluminum Crankshaft Pulley> Stainless Brake Lines> Phenolic Spacers> Perforated Brake Rotors (dint like, OEM now)> SmallCar Shift Kit (resting since TCU MOD)> 7-Position Ground System> High-Pressure Fuel Pressure Regulator (resting)> ATF Cooler & Campaign Filter> Yellow Polish Polyurethane Bushings> Pioneer Double-DIN Stereo with JL AUDIO Speakers> Driveshaft Rebuilt with C-Clip U-Joints> 15 Min MOD> 20 Min MOD .. . (2011) ![]() ![]() |
#42
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
#43
I meant that the phenolic spacers came with attached gaskets. They dint work for me! The gaskets slowly slid after mounting.. .
![]() Maybe they changed their gasket "goo" .. to hardening type.. ??? ![]()
#44
Yea, I understand what you meant. I saw some complaints about those in some older threads. They just did away with the gaskets, and now you have to order 2 sets of each OEM gasket separately from Subaru.
#45
The factory gaskets work fine.
