#421
Re: Individual Throttle Bodies and Improved Airflow
Hi Mike,
I have 2 different size heads this one and a larger one. On the old mill I used it to cut gears for work. Also we have electro magnetic vibrators and we need to build the coils in house so we use the 4th axis to make the bobins. Back to the throttle if you look at the image you can see how the bearings are mounted on each end of the roller. I need help from someone, do any of you guys have a 2 or 4 barrel carberater and can post a image of how the linkage works to open the second barrel. I am thinking of opening one roller fully then the other to try to help with performance at low revs. I remember Rally Bob and others telling me that rollers have poor performance at low throttle setting. Have a great day. Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. |
#422
Given what you suggested Adam about dropping the height of the ram pipes I am looking at going straight with them. Interesting enough there is a cout out in the bonnet support frame that means the ram pipes have a bit more clearance to fit. The last choice is the bonnet bump as suggested so anyway they will be straight.
Tony
#423
Hi Harvey,
I measure the air flow distances for you. Its a bit hard but its the best I can get for you. Valve stem to head were inject manifold attaches is 78mm. Injecter tip to face of head 25mm. Injector manifold is 80mm thick. I have measured the intake manifold (throttle manifold) that bolts onto the injector manifold. Its a bit hard to work it out exactly but I am pretty close. Distances are the best I can figure, hope it helps. Assume first row front of engine left side left bank, right side right bank. 165mm 195mm 175mm 175mm 185mm 185mm In other words from the valve stem to the tip of the intake on the front right is 195mm 80mm 78mm gives a grand total ram pipe length of 353mm total length. so therefor the shortest length is 323. Hope that helps. Tony
#424
The new throttles are
170mm ram pipe. 50mm throttle. 78mm valve to head 298mm total Don't forget my pipes are 42mm diameter compared to Subaru 45mm. Tony
#425
Have been away a bit had to send kids over seas , 1 to UK for 6 months & 1 to US for a month.
Anyway I have been working on the intake design and talking to Harvey as a result he suggested and I accepted that we should have the ram pipes at different length. I have given this close consideration and it makes sense. What Havery pointed out to me is that if all ram pipes are the same length then the power curve will have a massive spike in its power. If we have each pipe at a slightly different length the peak power may be lower but it will be for a longer time. It should be eaiser to drive. Just incase you were wondering that is why I measured the standard intake we have. I support the logic and given the problem of clearnace at the front of the motor a lowering of the intake pipes will help. So the plan is 20mm short on front 2 cyclinders & lengthen the back 2 by 20mm. Net result will be a 40mm length range from longest to shortest. Happy to here what everyone thinks. Tony
#426
Glad to see you're making good progress.
So I'm curious now. After all the work/research you've done into intake designs so far, what do you think of the stock intake?
#427
I personally think the numbers we saw from flow benching the intake manifold it is holding the engine back from developing more power. What is surprising me is the number of mods made to engines for not a lot of gain. I think the we need to step through the mods to figure whats best.
Tony
#428
Weekends are always go for this project. Started framing up the airbox to be used as the mould. Was surprised how well the MDF milled. The parts I have made so far came out really good. I have attached a PDF of the mould with the base left off. The gap between the two halfs is 18mm to allow for the seal and the thickness of the fibreglass. Haven't got enough experiance to say how thick the fibreglass needs to be.
Tony
#429
Doing some airflow calcs for the MAF units, can someone jump in if they are wrong,
at 8,000rpm the engine draws 4,000 fills of 3.3l's times the effectency factor of 1.15 gives 15,180 litres per min or 910 cuc metres per hour at 20 degrees C 1cubic metre of air weighs 1.204 Kg There for the engine would use 1,096kg of air per hour. If we all agree then the largest bosch airflow meter would not do it. Clearly we need 2 of the units that do 640kg per hour. Doing the calc these units will last up to 9,400 rpm which is well above target rev range. Need bosch unit 0 280 217 531 curve 3 Tony
#430
Tony, is 910 cuc the same as 537.7 cubic feet per minute?
#431
Hi
I think that number is wrong Cuc ft would be a larger number then 910 cuc metres not sure of the conversion. Tony
#432
OK, what is "cuc metres"?
#433
I think he means cubic meters.
Edit: Or maybe cubic centimeters?
#434
Sorry cubic metres.
#435
Here are some shoots of the top part of the airbox for want of a better name I have called the job "Oz Power".
This shoot is of the top plate on the airbox being millied, there is a 14mm slope on the plate to give it strength. Finished plate after sanding. Here it the assembled airbox I have to put filler in the corners to decrease the radius on the bends. Have done some of the bottom, had drama sorting it out for the 2 MAF units, figured I will go with units from a SVX as I have a couple of them spare, Tony
1995 - SVX 700,000 K Mine, DMS Struts to lift car 2in. Tyres Wrangler Silent Armor 235/70R16, PBR Radiator. 6 speed with DCCD and R180 rer diff, Heavy duty top strut mounts front and rear. Speedo correction box fitted. New stero (gave up on the old one). Back seat removed and 2 spare tyres fitted for desert driving. ECUTune SC sitting in the box for the next SVX. 1992 - SVX 255 K Wife (Want to stay Married so not allowed to fit SC) 1992 - SVX Pearl with black roof race car roll cauge etc ready to race. Ex Tasman Targa car. 1995 - SVX Green low k mint condiation. 1995 - SVX Rally car, ex Matts car. Now to be used on track. 1992 - SVX red & Black being converted to Mid Engine. 1995 - SVX Red 143,000 bit rough. Owned 5 others Subaru back to a 1974 1400 GSR. Last edited by Dessertrunner; 06-19-2011 at 12:14 AM. |
