Old 11-06-2011, 03:26 PM
svxhunter svxhunter is offline
5 speeds rock! :D
Re: Wheels that fit the SVX
Anybody try 17" x 8.5"?
I've got a good lead on a set of Rotas with a +48mm offset from an '05 STI.
'92 LS-not-so-L: the "SVreX"- Saved from a crusher, an SVX racer built by home schooled students for less than $2000 (including purchase price). 13.8 second 1/4 mile. Autocrossing monster!!
'92 LS-L Claret: '01 RS 4:11 5-speed, Exedy organic, lightened flywheel, and Koni/ GC
Old 11-06-2011, 03:44 PM
The Hunter had a set of these;
Gold Axis Se7en 18" rims, 18" Pirelli P-zero systems
Old 11-06-2011, 06:13 PM
Alcyone Lunacy's Avatar
Alcyone Lunacy Alcyone Lunacy is offline
FLATT racing div.
Thanks for all the feedback. I may just wait till I get all else done (mech, suspension, and body) then do the rims last. That would be like icing the cake, you gotta bake it first!
Tom, I will be emailing you for an appointment soon!
1986 4WD Turbo XT coupe 5sp.(XTINCT)
1987 4WD Custom Turbo XT coupe (XTLUNAC)
1992 SVX LS-L (LUNACY)
former:
1991 4wd XT6 5sp. (SUBDUED)
Old 12-05-2011, 09:05 PM
wolfboy wolfboy is offline
Hey guys I just picked up a set of momo 17x8 I think are +38 offset wrapped in 215/45/17's. Will the +38 on 17x8 be an issue?
Old 12-05-2011, 09:42 PM
Nemesis Destiny's Avatar
Nemesis Destiny Nemesis Destiny is offline
6MT STi-ified, now with R180!
Send a message via ICQ to Nemesis Destiny Send a message via MSN to Nemesis Destiny
I doubt it. Especially not with those pizza cutters you got with them.
1992 LS-L Touring, Liquid Silver w/ Black, 110k mi. "Alice." Rebuilt title. Mods: WRX 6-CD changer, 17x8" Motegi LC-12 (16.5lbs), PWR rad, Perrin LCP, JDM v.8 6MT + R180, Koni + Ground Control (325f/280r), Earthworm Bushings. Awaiting resto.
1994 LSI The legendary "Shotgun Slade" 110k mi and still going strong!
2005 Outback XT Limited 5MT, Obsidian Black Pearl, 211k km, daily driver.
1999 Mazda MX5 base 5MT, Twilight Blue Metallic, 152k km. "Twilight Sparkle" Summer daily driver!
2007 Honda CR-V, some awful shade of light green *yawn*
1992 LS-L Touring, Ebony Mica, 176k kms. Parts car. SCRAPPED.
1992 LS-L, Dark Teal, 367k km. "Wintergreen" the winter beater.*SCRAPPED due to rust*
Old 12-05-2011, 09:56 PM
Thanks! I know 225's would be a better fit, but for $300 for the wheels and tires I figured I can live with it
Old 12-05-2011, 10:04 PM
Yeah, sounds like you got a decent deal. Post some pics when you get them installed
Old 12-11-2011, 07:42 PM
Jvan Jvan is offline
When I swap my present summer rims/tires (Gold STI rims/Potenza tires) for winter tires/rims, the present tires need to be replaced in the spring. I can get a good deal on 2007 Tribecca rims w/stock tires. The stock Tribecca rims will fit but what about the stock tires?
Old 12-11-2011, 08:34 PM
The stock tires for a 2007 Tribeca are 255/55/18s.
They are they 16.8% taller numerically,
so they are MUCH, MUCH harder on your transmission!
They are about 5" taller,
and weigh about twice as much.
Old 12-11-2011, 08:41 PM
They also won't fit in the wheel wells, and i'd take a guess possibly the spring perches as well
Old 12-11-2011, 08:42 PM
A quick check at tirerack.com shows the 07 tribeca tires as 255/55-18 size. So, uhh, big. Stock SVX tires are 225/50-16. The tribeca tires are 4 inches higher. Speedo would be off by 17%, and the trans would have to work 17% harder to move the car (I think. Right?). Anyways, not even close, you'd need to get different tires. Those tribeca rims look nice on an SVX though...
Post some pics of the STI rims on the SVX .
Old 12-11-2011, 09:13 PM
Green1995SVX's Avatar
I hope you're not intending on, uhh.. turning. Or moving, really.
2009 Volvo C70 T5
2008 Volvo S80 V8
2006 Range Rover Sport
2001 Audi S8
Old 12-11-2011, 10:02 PM
I'm anticipating when I take off the snow tires in the Spring. I will need to replace the Potenza's that are coming off for the winter because their shot. I can get the Tribecca's w/ almost new takeoffs and I'll sell the tires to help purchase new tires. I'm looking for suggestions for replacements tires and size to fit on the Tribecca rims and fit the SVX.
Old 12-12-2011, 12:10 AM
A 245/35R18 will be less than .5% out (slightly smaller than stock), while a 225/40R18 will be ever so slightly larger (not quite 1%). I don't know if the 245 will fit without rubbing. Probably depends on the condition of your suspension.
Old 12-12-2011, 08:09 PM
Tapani Tapani is offline
I have the (-08?) STi 8x17 53mm ET wheels with 225/50-17 studded Nokian tires installed..... seems to work well.
What are the correct nuts for these wheels on an SVX? They have cones, but the Forester nuts I put in seem just a tad too small in outer diameter (cone part).
Do I have to get OEM STi nuts?
Thanks,
Tapani
