Go Back   The Subaru SVX World Network > SVX Main Forums > MOD Mania > ECU Tune Projects
  #406
Old 09-27-2007, 01:58 PM
yeah but with the new motor he is only seeing 6.5psi of boost. There is a significant amount more flow as far as i know now. i need to get mine done this weekend in order to compare....
Speaking of. My head studs from ARP showed up today. Yesterday I got my block halves together and my odd piston rings cut and all 3 pistons loaded. Today I plan to finish the even side and get the studs in the block. I also plan on doing the porting to my exhaust side of the heads. If all is finished in a timely manner I will have the heads installed on the motor. Only thing I am waiting on now is my intake cams which should be in the mail... Lets hope they are here by saturday. I still plan on pulling the motor out of the car this weekend and begin moving the s/c parts over onto the built motor. This weekend should be a doozy if the cams come
Old 09-27-2007, 05:32 PM
sicksubie's Avatar
dynoing tomorrow ( fingers crossed)
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1995 Guards Red Carrera
1957 CJ-5
Old 09-27-2007, 06:44 PM
Well... the short block went together with ease. Installed the ARP head studs, sealed them to the block. Installed the rebuild heads and torqued the arp studs to 72ft lbs using the Moly lube they supply. You could also tq them as far as 93 ft lbs if you used 30 weight oil but I'd rather us the moly as it is meant for it.... Long block is almost complete... tomorrow I finish up as far as I can go with the motor and then I pull the car in to begin removal of the old one.... Fingers crossed on those intake cams
Old 09-27-2007, 07:42 PM
Can't forget these... Sorry for the quality but I need to find my card for the camera
Old 09-27-2007, 07:46 PM
That's hot. Can't wait for dyno numbers!!!!!!
Old 09-28-2007, 11:39 AM
cdigerlando cdigerlando is offline
ARPs
Great to hear. Glad the ARPs fit. Did the sealer and lube come with the kit? Mine has not arrived yet. I went ground.
Chuck D.
1992 Subaru SVX LS-L - Heavily modded turbo
2002 Subaru Impreza WRX- Turboxs stg3 & Susp. Mods
Old 09-28-2007, 01:55 PM
the lube came with them but the sealer didn't I used the ultrablack that I used on the block as well... More progress as soon as I can make some
Old 09-28-2007, 05:21 PM
sicksubie's Avatar
DYNO Results
Well I got to the dyno today and did three pulls. The numbers were bad but there are a few issues to be resolved. One, I need more fuel pressure ( i.e buy a walbro and an adjustable FPR), Two, there was a possible boost leak and or belt slippage, and three the leak in the exhaust needs to be fixed. The leak was causing their AFR numbers to be skewed. The one good thing is that we seem to have corrected the curves with the new cam profiles. The curves look great ( they just need to move up a lot)
Sorry in advance that they are just photos of the charts. My scanner is not compatible with Vista.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
Old 09-28-2007, 05:25 PM
SVXRide's Avatar
SVXRide SVXRide is offline
Official AutoX Part Breaker
Hard to tell from the photos...did your HP peak out at ~235? how about TQ?
-Bill
Retired NASA Rocket Scientist
Center Network Member #989
Old 09-28-2007, 06:04 PM
longassname's Avatar
Just some dude.
Pretty good for 5 and half pounds boost. It looks like the engine is making torque out to 5750 rpms--below that the torque looks to corelate with the falling boost. When boost falls as RPMs go up it's usually due to belt slippage. Don't forget with blowers the belt doesn't squeel when it slips. You have to watch the boost and look for powder in the engine bay. By the looks of those plots, put the larger crank pulley on and tighten up the belt and we should see some big numbers.
Old 09-29-2007, 07:49 PM
Welp.... the old smokey motor is out and I am in the process of cleaning, resealing, and swapping all the parts over... No cams yet Or else I'd still be at the garage abusing myself to get it done faster
Old 09-30-2007, 06:31 AM
Um, thanks for sharing.
Old 09-30-2007, 07:25 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
I hope you don't abuse yourself on my coilovers
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 09-30-2007, 07:29 AM
quick opinion... catch can or just vented crank case??? what do you guys think?
Old 09-30-2007, 07:49 AM
sicksubie's Avatar
why no catch can on mine?
BTW I am now seeing 11.5psi. There is still belt slip however that I am trying correct.
Former:
Current:
2017 Ford Raptor
2017 Kawasaki KLR
1957 CJ-5
