Old 04-04-2012, 06:37 AM
Re: $36 Replacement ignition coils?
Nice top mounts!
Brake fluid is low.
Old 04-04-2012, 08:14 AM
Chuckls's Avatar
Chuckls Chuckls is offline
Designated Asshole
Gotcha....I'm gonna take a look at mine in a bit. I think I'll be doing that.
So any benefits? I know you said better flow and more get-up, but could you explain?
Old 04-04-2012, 07:35 PM
smc smc is offline
Nice top mounts!
Brake fluid is low.
Thanks. 2007 STI coilovers. Ill do a writeup on them soon. Its really just a few hour procedure. I dont know why people spend such big bucks on custom coilovers for the svx when all you have to do is drill 3 holes on the top mounts.
heh, I suppose its time to get new pads on the brakes! Thats would bring it right back up
With the stock canister style of filter, the fuel has to flow from the top center of the can, through the filter media to the outside then back up to the top of the can and out to the engine. The fuel has to completely reverse direction to get out of the filter. this causes turbulence in the flow of the fuel.
It would be like you running at a full sprint, then suddenly realizing that you missed the door you need to take to exit. So you slam on the brakes, take and about face and exit.
The inline filter allows for a better flow path. In the top, filter media, then out the bottom. Just like sprinting, taking a step to the left and continuing onward.
I have no proof of performance gains, but my butt dyno notices that the car just feels more.. Peppy. Seems like she has better throttle response. When i stomp on the throttle, its instant vroom. No hesitation.
Old 04-04-2012, 09:27 PM
ShiuludeSVX's Avatar
That coil config is just nuts. I gotta do that while I'm contemplating the tranny fix.
Thanks for the big idea.
The Worm
_______________
June '91 Claret LSL #1733, Enkei RS-5's x 16", Original Paint, accompanied by Beautifully speckeled Front Bumper, Sony Audio Components, Small Car Shift Kit, "How to" Hood Lifts {Perfect}, "15 Minute Suspension Mod"
Motorsport Floor Mats. Perma-Cool External T. Filter, New Front Axels {1/2008}. "Classic Radiators" unit "$36 coil alternative" and Tranny rebuild at 287k 8/2012
'05 Infinity G35 Coupe.
No Mods, 33K Miles
Old 04-04-2012, 09:39 PM
Originally Posted by smc View Post
The stock filter has only one line. The inlet from the tank and the outlet to the fuel rails. The other two are just tank returns. ... At least thats the way it is on the 96. ? Hmm. I dont recall how it was plumbed on my old 92.
There are 3 lines:
The one from the fuel pump, which passes through the fuel filter
The fuel return line
The one that goes to the charcoal canister
Old 04-04-2012, 09:43 PM
What exact coilovers did you use?
The main point of contention for the front struts is the bracket that attaches to the endlinks for the front swaybar. How'd you solve that problem?
Old 04-04-2012, 09:50 PM
Chuckls's Avatar
Designated Asshole
Uh oh..I keep meaning to put a check valve in that.
Old 04-04-2012, 11:04 PM
smc smc is offline
Easy. I tossed the swaybar in the trash. The stock swaybar is pathetic. Its diameter is so small they might as well have not used anything at all.
My solution
Old 04-04-2012, 11:09 PM
So did you already put that ^ bar on there, or is that just the plan? That looks like just the thing I've been wanting. Where do you mount it though?
Old 04-04-2012, 11:17 PM
smc smc is offline
Thats the plan. When the car progresses further and I can get an accurate weight balance measurement, then I can get the proper calculations for length and diameter and get to fabricating. If all goes according to plan *never does* It will mount in place of the stock swaybar. As for mounts to the suspension it just welding on some tabs. Ill be fabricating tubular suspension components once I have the time to make a jig. I may offer them for sale in stock SVX mounting or STI conversion configuration.
Gawds.. Not like im helping here, but this tread is getting way off course
Old 04-04-2012, 11:27 PM
A little off course is pretty much the norm here.
What I've heard is that you can't mount a straight swaybar where the stock swaybar goes; the stock one is bent to get around/through the subframe without touching it. That makes things more difficult.
I'd buy a front swaybar, even if it's just a one-off. It would go well with the giant one I have in the rear.
Old 04-05-2012, 12:01 AM
smc smc is offline
I still have the oem front swaybar. Im looking at it right now. Ill post up a picture tomorrow as its getting too late now, but its a really minor bend of 1/2". Otherwise its dang near just a strait bar. o.O
Old 04-05-2012, 12:15 AM
I have never had the opportunity to check it out myself. If you could get a straight bar through there, that would be great.
Old 04-05-2012, 09:14 PM
smc smc is offline
*chuckles* What passes for a front swaybar on these cars.
Pretty much just a strait shot.
Old 04-05-2012, 09:34 PM
Hmm. I imagined it would be more bent than that. Still, might it be enough that it will mean a straight bar will rub against the subframe if one does fit?
