Re: Slow Overheating SVX; please help!
I kind of feel stupid now because I meant to replace the cat converter a few months ago as an upgrade anyway and I put it off and put it off because I was moving....
But I got this from another website and this is exactly what is happening with my car.... "Catalytic converters are defective when they become clogged or poisoned. You may sometimes be able to feel when a converter is partially clogged, or defective, when you do not go any faster when you step on the throttle. This may also be accompanied with a noticeable drop in gas mileage. A clogged converter will cause increased backpressure in the exhaust system. This increased backpressure prevents the engine from breathing properly which in turn may cause the engine to quit after a few minutes of driving or feel like an engine governor limiting the RPM's the engine can achieve. You may actually hear a whistling or choking sound when applying the throttle." |
A clogged cat can smell bad. I've heard it described as a "rotten egg" smell.
Everything a shop does will cost a ton of money, regardless of how easy it takes or how long.
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
easy, take out your o2 sensors and see if it runs better. plugged cats can cause your symptom but it's not the actual cause of the event, a new cat would likely get plugged as well. your car might have an issue with running too rich.
Shouldn't a code have been thrown if his CAT was clogged?
Tony 1996 Polo Green Subaru SVX LSi, 168,XXX miles, Redline D4 ATF, Redline 75W90 gear oil, K&N HP-4001 Oil Filter, Mobil 1 5W50 FS (3qt) and 5W30 High Mileage (4qt) Oil Blend, Motul RBF600 Brake Fluid, AC Delco A975C Air Filter, NGK BKR6EIX-11 plugs, Centric Rotors, Power Stop Evolution Carbon Fiber Ceramic Brake Pads 2005 Gray Acura RL, 165,XXX miles, Redline D4 ATF with Lubegard Platinum Protectant, Mobil 1 5W20 High Mileage Extended Performance Oil 2009 Red Toyota Venza, 123,XXX, Mobil 1 5W30 High Mileage Oil 1992 Red Ferrari 348 ts, 82,XXX, Redline everything |
Nope, Mr Third-O2-sensor. The 2 O2 sensor cars have the O2 sensors before the cats, so they have no way of knowing if the cats are even there.
What?
"That which can be asserted without evidence can be dismissed without evidence." '92 Dark Teal SVX LS-L, >146,000m 3 pedals, 5 speeds., restoration underway. 2012 Honda Insight, slow but cute. ![]() |
Yes, all of this quote is much too high. A new-from-Subaru water pump is less than $200, as I recall.
Remove the front O2 sensors from the headpipes.
Let them dangle. Wait about a day to let it all air out with the battery dissconnected. Reconnect the battery, start it and let it run WITH the O2 sensors still out and the headpipes NOT plugged. After running it for, say 1/2 hour take it for a drive, as is, and report back. If the exhaust is plugged with the O2s out, now it can breath. If the O2s are soaked in unburned gasoline, by now it they are dry.
1992 Pearl White LS Owned since 2009 175k Miles STi Airlift Performance air suspension 2005 WRX manual swap Rear wheel drive ![]() K-Staff front bumper Delta Speed side skirts JDM clear corners Smallcar grille Subaru XT steering wheel Subaru XT shift knob First bagged SVX in the world Worlds first SVX on air suspension. Custom made (by myself) spare tire subwoofer. |
Where's the update? Did you try the new radiator cap? Have the water pump and thermostat checked out? Have the CAT checked for clogging?
