Old 05-04-2009, 06:16 PM
Re: AIRBAG light... will it halt an inspection?
The airbag deploys at 200 MPH and with your face about an inch away as you reach for some pretty yellow wires it takes your head cleanly off,
or snaps your neck and then dents the roof with your head..
And we don't want no dented roofs.
Right, the roof. Gotcha. Fixing those can be a pain.
Old 05-05-2009, 11:28 AM
Szalkerous Szalkerous is offline
Send a message via AIM to Szalkerous
Does anyone else find the irony in this conversation? Killed by a safety device..... rich. I'll probably choke on the seatbelt too, for good measure.
In other news, I'm usually pretty good about keeping my face away from airbags when working around them.
Wish I could disable the entire system and call it a day. Just entirely too lazy for that. I'll have to figure out where my disconnect is.
-sz
1994 SVX LSi - Black / Beige - 139k miles SOLD!
1999 Chevy Camaro Z28 - Black, 6-speed, hell of a ride.
2004 Chevy Silverado Z71 - Blue LT2 luxury package
Old 05-05-2009, 11:33 AM
Slightly askew from topic, but isn't it possible to remove the airbags and reassemble the wheel and dash so it appears to have one?
Old 05-05-2009, 02:59 PM
Blenderhead Blenderhead is offline
The dash would be easy. Re-assembling the steering wheel to appear to have one would be a little more difficult. However the catch is turning off the light. Airbags have a certain amount of resistance to them, and the computer needs to see that amount of resistance, which is different for different types of cars and different for passenger airbags vs drivers airbags etc. In theory you could just put the appropriate resistor inline with the wiring, but the catch is figuring out what the resistance is supposed to be, because just hooking up the ohm meter to the airbag will be enough to blow it off.
MY TOYS
95 SVX
98 Lincoln MarkVIII LSC, 5-speed swap
91 Marcury Cougar, 393" stroker, completely insane!
89 Mercury Cougar XR7, supercharged V6/5-speed, one of 2209. Engine currently dead, replacement in garage being rebuilt.
80 Pontiac Firebird formula, 350TPI swapped in, car needs to be finished.
Old 05-05-2009, 03:57 PM
"If you hide your light under a basket, no one will see it."
St Luke.
Old 05-05-2009, 05:49 PM
-sz
If you want to choke just try backing up on a dark night and open your door and poke your head out. The seatbelt will do it's best to get you.
Old 05-05-2009, 09:02 PM
BoxerFanatic's Avatar
Wow.
This thread is looking like a good excuse for a 92-to-early-94 non-airbag dash, a nice three-spoke racing, or aftermarket bag-less steering wheel, fixed seat-belts, and removing the airbag bulb and fuses from the system.
Just Manual seatbelts... like the old days.
Old 05-05-2009, 09:33 PM
Originally Posted by BoxerFanatic View Post
Wow.
This thread is looking like a good excuse for a 92-to-early-94 non-airbag dash, a nice three-spoke racing, or aftermarket bag-less steering wheel, fixed seat-belts, and removing the airbag bulb and fuses from the system. Just Manual seatbelts... like the old days.
I believe that removing that bulb will cause the car not to start.
Old 05-05-2009, 09:57 PM
They just don't make it easy, do they?
Old 05-05-2009, 10:15 PM
Really? Is that a subaru only kind of thing or something? Cause I've never heard that before. I kind of doubt that is true, just cause it seems like something that would be quite a bit of work for them to set it up that way, especially on a car that originally came without airbags. I'll look up the wiring diagrams on it tomorrow at work though to double check.
And Boxerfanatic, I'm right there with you. I personally hate airbags, and I feel much more comfortable in a car without them. I have actually disabled them in some of my cars that I have had. If I'm going to hit something doing 40-50mph, why would I want a wall of canvas flying at my face at 400mph? I've seen those things detonated outside, and I have even seen them used to launch engine blocks in the air and flip small cars on their sides, so its definitely not something I want pointed at my face. Plus I was in one serious accident in a car with no airbags but wearing my seatbelt (got hit head on by a full size chevy pickup going 40-45 while stopped in a tbird) and while I had a huge bruise across my chest from the belt, I walked away without a scratch otherwise, so I really have no use for those things.
MY TOYS
95 SVX
Old 05-06-2009, 05:54 AM
I removed the airbag light to pass the Quebec safety check and the car ran fine. There is actually a small circuit board with about 5 wires attached to it that must be removed.
Old 05-06-2009, 10:44 AM
I just checked the wiring diagram, and there is no feedback to the airbag control module from the light. The only thing is one wire going from the module to the light which supplies power when it wants to turn the light on. If the bulb were missing, nothing in the car would know the difference, so it wouldn't prevent it from starting.
MY TOYS
95 SVX
Old 05-07-2009, 09:25 AM
Thank god. I need to pass this inspection, one way or another. If the bulb has to go temporarily, so be it. Afterwards I can hook it back up and properly troubleshoot.
