Re: Sicksubie's S/C set up
More pics, more pics!
Tim 92 Liquid Silver SVX 5MT 2009 BMW Z4 (Gone) 2012 Camry V6 SE |
Hydra engine management = no MAFs at all
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 |
Former: 1994 Barcelona Red(x2), 1995 Brilliant Red, 1992 Liquid Silver, 1992 Ebony(x2), 1992 Pearl White (x2) Current: 2017 Ford Raptor 2017 Kawasaki KLR 1995 Guards Red Carrera 1995 Spec-ish Miata - track car 1957 CJ-5 Last edited by sicksubie; 03-19-2010 at 12:29 PM. |
looking great! that thing should be wicked fast.
~Phil Teal 1992 Subaru SVX Turbo - Sold in May 2011 to peace-frog. |
Is that "wicked" a dig at me being from New England?
Naw, Im not trying to be smawt or anythin
I got a bunch done tonight.. Pics to come tomorrow. The alternator is now relocated, my 12psi pulley is on (actually 14psi), the intakes are on, the new clutch hard line is run, the PS fluid cooler (huge one) is installed, the Braille battery is in place, and I got most of the wiring redone tonight. I am basically waiting on a radiator, non-ABS hard lines, and I am cutting and reshaping my methanol reservoir so it fits better in the engine bay...
Is that a temp sensor on the back of the R180? Or what?
'94 Laguna Blue LSi ~159k.......JDM ultra short-geared 3.900 STi Version 7 6-speed w/ Cobb shortshifter, ECUtune 244,8.1mm/256,9.1mm i/e cams, group N motor mounts, '97 grille, JDM clear corners, Momo JDM Legacy GT steering wheel, apkarian's LED tails, silver STi BBS wheels, PWR radiator, redstuff pads f/r, drilled/slotted rotors, bontragerworks rsb #18, Koni/GC 450f/375r coilovers, Megan Racing adjustable lateral links, KMac c/c plates, Stebro exhaust, ECUtune 1v5, Optima battery in the trunk where it belongs. Turbo project '97 Ebony LSi ~137k #036.......Power mode mod, JDM clear corners, BBS wheels. AUX/pocket mod Now a mod "over there" ![]() |
Yep, it is...
Actually had a free evening here to work on the car and decided to tackle the fuel pump. Opened it up and apparently the former owner had already replaced it with a 255lph fuel pump by TRE performance. The wire clip is the same as the walbri so no splicing and dicing for me. I am going to still put install the Walbro and if anyone wants the other 255lph fuel pump cheap let me know...
ordered camber plates from K-MAC, ordering 255/35/18 Toyo R888's this week, and hopefully getting a radiator soon*
OT???
#28
pics?????? I will have some pics of my classglass hood with scoop soon for you to gander at
![]() ps need mas detailed and noted pics of the GC weldage... |
#29
#30
The car is on the ground and ready to roll with the exceptions of greasing the rear swaybar bushings, wiring in the methanol injection, getting a radiator from OT, fluid check up, rewelding an exhaust hanger, and then fabricating some sort of tie down set up for the 11lb Braille battery. I might explore a new steering wheel before the Cumberland auto-x too. I want/ need something a little smaller in diameter.
OT, I will need a STi top radiator hose you said correct? What about a cap? I assume my OEM STi one will work?
