Old 09-22-2007, 11:44 AM
Originally Posted by MacGyver View Post
What's the going rate these days on a sets of rotors for the SVX from these guys?
On the Race Concepts site they list for $180 for the fronts and $180 for the rears. Pads are $50 front and $45 rear. There's no SS lines listed for the SVX on the site, but apparently they exist.
http://www.raceconcepts.net/list.php?section=rotor
Old 09-27-2007, 01:18 PM
Crysis Crysis is offline
AK Rowdy
Send a message via AIM to Crysis
Hmm so I have been calling race concepts for over a week now, leaving a voicemail everytime, and they still havnt responded back. Anyone else get ahold of them?
Old 10-05-2007, 07:26 PM
I spoke with him tonight, and the other day to order some more sets of his Plated, Dimpled and Slotted rotors, pads, and Stainless Steel lines.
With the changes to our computer/network thingie at home, I had actually NOT E-Mailed him so when Di sent out my E-Mail he called right away.
If you guys want me to, I can stock up on his SVX rotors/pads/ SS lines and you can get them from me..
On monday I'll find out what sort of discounted price I can get/give.
More later,
Old 10-05-2007, 09:53 PM
94SubieSVX's Avatar
OOC for a while
I'll eventually get some if you decide to stock up...I want some fancy breaks and row-ters
bLAh
Old 10-06-2007, 05:17 AM
Tim's Avatar
Tim Tim is offline
My car's Italian, right?
Send a message via AIM to Tim
Hooray for Tom possibly becoming a distributor
Tim
92 Liquid Silver SVX 5MT
2009 BMW Z4 (Gone)
2012 Camry V6 SE
Old 10-06-2007, 03:40 PM
More later,
I'd be on board for ordering a full set of everything in a little while. I don't have the finds for a full brake overhaul right now, but I should soon.
Old 10-06-2007, 04:23 PM
shotgunslade's Avatar
I have FrozenRotors on my car. Have to say that they are good. Use them with Axxis Ultima pads. Good combinatino. SDeen me thru a number of tracks days.
Old 10-07-2007, 06:29 AM
CorSVXette's Avatar
Classic SVX
More later,
Count me in. I don't hink I need them right now but I will definetly buy them now and put them on when I get the chance. Thanks Tom for looking out.
ps. How would I know if my rotors are warped?
Paul.
Old 10-07-2007, 09:48 AM
Paul.
If your car shakes when you apply the brakes, AND your suspention parts, ball joints, tie rod ends, alignment, etc. are all fine and tight, then your rotors are probably warped.
If you have a dial indicator with a magnetic base, then you can remove your wheels and tires, reinstall at least three wheel nuts per rotor, and check for warpage that (the correct) way.
The discard thicknesses for the front and rear rotors are; 1.024" front,
and 0.335" rear.
Old 10-08-2007, 02:07 PM
I just got off the phone with Bein!
I am going to be able to sell Race Concepts Dimpled, Slotted, Plated Rotors, (sets of four) Pads, (for all four wheels) and Stainless Steel Lines for
$375.00!!!
Shipping will be through DHL, cheap and insured.
Or you can pick them up here.
More later.
Old 10-08-2007, 02:19 PM
You're officially my hero! At that price I'll be getting in touch with you about a full set in a couple weeks!
You may want to start a new thread like the HID for SVX thread for sign ups and ordering. I think you're going to have a lot of orders.
You may have to build a small warehouse if this distributing thing goes much farther.
Old 10-08-2007, 04:07 PM
SVX_MY_BABY's Avatar
Originally Posted by RSVX View Post
I have been using ART Cryo Rotors for >5 years, and no warping... and its not like I haven't tried.
That's what I have. Love em. They also gave a discount to the group.
http://www.subaru-svx.net/photos/fil...BABY/4388.html
Old 10-08-2007, 04:16 PM
94SubieSVX's Avatar
OOC for a while
WOW, ok so new brakes on on the "soon to come" list now
bLAh
Old 10-08-2007, 07:36 PM
Turbone Turbone is offline
Banned
Send a message via ICQ to Turbone Send a message via AIM to Turbone Send a message via Yahoo to Turbone Send a message via Skype™ to Turbone
Ditto.....
This month, wheels and tires.
Next month, rotors and brakes
Old 10-09-2007, 07:15 AM
CorSVXette's Avatar
Classic SVX
$375.00!!!
More later.
Hi Tom. Are you taking orders yet?
Paul
1969 Corvette
1995 Corolla
2003 Highlander
